AndrewFG
(Andrew Fiddian-Green)
October 28, 2022, 1:26pm
22
All the other times occurred AFTER a kodi offline message (and no indication that it had gone online againβ¦)
hajeth
(Thomas)
October 28, 2022, 4:37pm
23
Of course, when the timeout occurs, the binding does not get online again. But after a restart of OH it is working for some days and then the error occurs again.
Letβs assume, the log with the Kodi entry before the timeout occurs is from monday, then OH was restarted and hung again at Wednesday, the Wednesday log did not show anything from the Kodi binding before the connection timeout.
The logs i attached here show only one occurence of the error. As far as i can tell, there are no common events in the logs before the timeout.
AndrewFG
October 28, 2022, 10:42pm
24
Ok, please let me know the results of your testing.
hajeth
(Thomas)
October 29, 2022, 4:18pm
25
Short update without news - IΒ΄m back home and no communication timeout with gardena server happened. That seems to confirm AndrewFGs guess that another binding is responsible for the break of some bindings. As I was away there were no PC starts(exec binding), no events of devices coming online (network binding, kodi binding) and the gardena bindinng does its pings and received pongs as it should be. So i have to wait for the next occurence of the error. I will report back, when the error occured next time.
Lolodomo
(Lolodomo)
October 30, 2022, 11:50am
26
Please list all bindings you installed.
Do you use MQTT / MQTT home assistant ? Look at this issue in that case:
opened 10:36AM - 22 Oct 22 UTC
I seem to encounter relatively frequent dead-locks with MQTT (homeassistant) bin⦠ding, every few days
**Summary**
I believe the issue is nested parallel stream processing, all using the same common `ForkJoinPool.commonPool` thread pool. The deadlock happens since BaseThingHandler synchronizes in `updateState`
Discussion on this issue:
https://stackoverflow.com/a/23480863
https://bugs.openjdk.org/browse/JDK-8042758
**Thread dump analysis below**
openHAB MQTT transport uses HiveMQ which then again uses Reactivex library for I/O. Threadpool named `RxComputationThreadPool` seems to be used for handling incoming data (`org.openhab.core.io.transport.mqtt.internal.Subscription.messageArrived`).
We can see that `RxComputationThreadPool-3` has locked the handler, since `BaseThingHandler.updateState` has `synchronized(this) { method body here }`.
We can also see that the trivial parallel stream processing in `ItemChannelLinkRegistry.getBoundChannels` seem to make the whole thread `WAITING`.
<details><summary>RxComputationThreadPool-3</summary>
<p>
"RxComputationThreadPool-3" Id=671 in WAITING on lock=java.util.stream.ReduceOps$ReduceTask@59d925
at java.base@11.0.15/java.lang.Object.wait(Native Method)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.externalAwaitDone(ForkJoinTask.java:330)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.doInvoke(ForkJoinTask.java:412)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.invoke(ForkJoinTask.java:736)
at java.base@11.0.15/java.util.stream.ReduceOps$ReduceOp.evaluateParallel(ReduceOps.java:919)
at java.base@11.0.15/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:233)
at java.base@11.0.15/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at org.openhab.core.thing.link.ItemChannelLinkRegistry.getBoundChannels(ItemChannelLinkRegistry.java:67)
at org.openhab.core.thing.internal.ChannelStateDescriptionProvider.getStateDescription(ChannelStateDescriptionProvider.java:94)
at org.openhab.core.thing.internal.ChannelStateDescriptionProvider.getStateDescriptionFragment(ChannelStateDescriptionProvider.java:86)
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getMergedStateDescriptionFragments(StateDescriptionServiceImpl.java:71)
at org.openhab.core.internal.service.StateDescriptionServiceImpl.getStateDescription(StateDescriptionServiceImpl.java:63)
at org.openhab.core.items.GenericItem.getStateDescription(GenericItem.java:409)
at org.openhab.core.library.items.NumberItem.getStateDescription(NumberItem.java:85)
at org.openhab.core.items.GenericItem.getStateDescription(GenericItem.java:403)
at org.openhab.core.internal.items.ItemStateConverterImpl.parseItemUnit(ItemStateConverterImpl.java:121)
at org.openhab.core.internal.items.ItemStateConverterImpl.convertToAcceptedState(ItemStateConverterImpl.java:79)
at org.openhab.core.thing.internal.profiles.ProfileCallbackImpl.sendUpdate(ProfileCallbackImpl.java:121)
at org.openhab.core.thing.internal.profiles.SystemDefaultProfile.onStateUpdateFromHandler(SystemDefaultProfile.java:53)
at org.openhab.core.thing.internal.CommunicationManager.lambda$13(CommunicationManager.java:566)
at org.openhab.core.thing.internal.CommunicationManager$$Lambda$1117/0x68b83628.accept(Unknown Source)
at org.openhab.core.thing.internal.CommunicationManager.lambda$15(CommunicationManager.java:586)
at org.openhab.core.thing.internal.CommunicationManager$$Lambda$1118/0x68b82e28.accept(Unknown Source)
at java.base@11.0.15/java.lang.Iterable.forEach(Iterable.java:75)
at org.openhab.core.thing.internal.CommunicationManager.handleCallFromHandler(CommunicationManager.java:582)
at org.openhab.core.thing.internal.CommunicationManager.stateUpdated(CommunicationManager.java:564)
at org.openhab.core.thing.internal.ThingManagerImpl$1.stateUpdated(ThingManagerImpl.java:176)
at org.openhab.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:268)
- locked org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler@110022
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.updateChannelState(AbstractMQTTThingHandler.java:263)
at org.openhab.binding.mqtt.generic.ChannelState.processMessage(ChannelState.java:220)
at org.openhab.core.io.transport.mqtt.internal.Subscription.processMessage(Subscription.java:85)
at org.openhab.core.io.transport.mqtt.internal.Subscription.lambda$1(Subscription.java:81)
at org.openhab.core.io.transport.mqtt.internal.Subscription$$Lambda$2050/0x662f4e28.accept(Unknown Source)
at java.base@11.0.15/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183)
at java.base@11.0.15/java.util.concurrent.ConcurrentHashMap$KeySpliterator.forEachRemaining(ConcurrentHashMap.java:3566)
at java.base@11.0.15/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base@11.0.15/java.util.stream.ForEachOps$ForEachTask.compute(ForEachOps.java:290)
at java.base@11.0.15/java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:746)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290)
at java.base@11.0.15/java.util.concurrent.ForkJoinPool$WorkQueue.helpCC(ForkJoinPool.java:1115)
at java.base@11.0.15/java.util.concurrent.ForkJoinPool.externalHelpComplete(ForkJoinPool.java:1957)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.tryExternalHelp(ForkJoinTask.java:378)
at java.base@11.0.15/java.util.concurrent.ForkJoinTask.externalAwaitDone(ForkJoinTask.java:323)
at java.base@11.0.15/java.util.stream.ForEachOps$ForEachOp.evaluateParallel(ForEachOps.java:159)
at java.base@11.0.15/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateParallel(ForEachOps.java:173)
at java.base@11.0.15/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497)
at java.base@11.0.15/java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:661)
at org.openhab.core.io.transport.mqtt.internal.Subscription.messageArrived(Subscription.java:81)
at org.openhab.core.io.transport.mqtt.internal.Subscription.messageArrived(Subscription.java:66)
at org.openhab.core.io.transport.mqtt.internal.client.Mqtt3AsyncClientWrapper$$Lambda$2013/0x665b5028.accept(Unknown Source)
at com.hivemq.client.internal.mqtt.mqtt3.Mqtt3AsyncClientView.lambda$callbackView$1(Mqtt3AsyncClientView.java:76)
at com.hivemq.client.internal.mqtt.mqtt3.Mqtt3AsyncClientView$$Lambda$2014/0x665b1028.accept(Unknown Source)
at com.hivemq.client.internal.mqtt.MqttAsyncClient$CallbackSubscriber.onNext(MqttAsyncClient.java:303)
at com.hivemq.client.internal.mqtt.MqttAsyncClient$CallbackSubscriber.onNext(MqttAsyncClient.java:288)
at com.hivemq.client.rx.FlowableWithSingle$SingleFutureSubscriber.onNext(FlowableWithSingle.java:406)
at com.hivemq.client.internal.rx.operators.FlowableWithSingleCombine$SplitSubscriber$Default.tryOnNextActual(FlowableWithSingleCombine.java:235)
at com.hivemq.client.internal.rx.operators.FlowableWithSingleCombine$SplitSubscriber.tryOnNext(FlowableWithSingleCombine.java:200)
at io.reactivex.internal.operators.flowable.FlowableObserveOn$ObserveOnConditionalSubscriber.runAsync(FlowableObserveOn.java:649)
at io.reactivex.internal.operators.flowable.FlowableObserveOn$BaseObserveOnSubscriber.run(FlowableObserveOn.java:176)
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66)
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57)
at java.base@11.0.15/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base@11.0.15/java.lang.Thread.run(Thread.java:829)
</p></details>
Rx threads 1 & 2 are also processing received MQTT data. Threads are `WAITING` state. `org.openhab.core.io.transport.mqtt.internal.Subscription.messageArrived` uses `parallelStream().forEeach`. `parallelStream()` uses common thread pool (presumably with limited number of threads available) behind the scenes, perhaps that is the issue?
`java.util.concurrent.ForkJoinTask:330` is waiting to be notified:
https://github.com/openjdk/jdk/blob/da75f3c4ad5bdf25167a3ed80e51f567ab3dbd01/src/java.base/share/classes/java/util/concurrent/ForkJoinTask.java#L330
<details><summary><code>RxComputationThreadPool-1</code> & <code>RxComputationThreadPool-2</code></summary>
<p>
"RxComputationThreadPool-1" Id=667 in WAITING on lock=java.util.stream.ForEachOps$ForEachTask@9bf2fa
"RxComputationThreadPool-2" Id=668 in WAITING on lock=java.util.stream.ForEachOps$ForEachTask@55cdd5
</p></details>
Rx thread 4 is idling
"RxComputationThreadPool-4" Id=672 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15870ee
at java.base@11.0.15/jdk.internal.misc.Unsafe.park(Native Method)
at java.base@11.0.15/java.util.concurrent.locks.LockSupport.park(LockSupport.java:194)
at java.base@11.0.15/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2081)
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1170)
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:899)
at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1054)
at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1114)
We can check all threads used by `parallel()`/`parallelStream()` by focusing on threads named `ForkJoinPool.commonPool-worker-#`. All of them are `BLOCKED` with `BaseThingHandler.updateState` since `RxComputationThreadPool-3` has `synchronized` using the very same thing handler.
<details><summary><code>ForkJoinPool.commonPool-worker-*</code></summary>
<p>
"ForkJoinPool.commonPool-worker-3" Id=232 in BLOCKED on lock=org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler@110022
owned by RxComputationThreadPool-3 Id=671
at org.openhab.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:267)
at java.base@11.0.15/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1020)
at java.base@11.0.15/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1656)
at java.base@11.0.15/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1594)
at java.base@11.0.15/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:183)
"ForkJoinPool.commonPool-worker-5" Id=669 in BLOCKED on lock=org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler@110022
"ForkJoinPool.commonPool-worker-7" Id=670 in BLOCKED on lock=org.openhab.binding.mqtt.homeassistant.internal.handler.HomeAssistantThingHandler@110022
</p></details>
<details><summary><b>Full thread dump</b></summary>
<p>
"CM Configuration Updater" Id=30 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1e7edab
at java.base@11.0.15/java.util.concurrent.LinkedBlockingDeque.takeFirst(LinkedBlockingDeque.java:483)
at java.base@11.0.15/java.util.concurrent.LinkedBlockingDeque.take(LinkedBlockingDeque.java:671)
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:73)
"CM Event Dispatcher" Id=31 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@13ecfe5
"Log4j2-TF-2-Scheduled-1" Id=45 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@3f33c6
at java.base@11.0.15/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:234)
at java.base@11.0.15/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2123)
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1182)
"fileinstall-/usr/share/openhab/addons" Id=46 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@1438d83
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:320)
"encryption-1-thread-1" Id=71 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@a9972c
at java.base@11.0.15/java.util.concurrent.LinkedBlockingDeque.pollFirst(LinkedBlockingDeque.java:513)
at java.base@11.0.15/java.util.concurrent.LinkedBlockingDeque.poll(LinkedBlockingDeque.java:675)
at java.base@11.0.15/sun.nio.fs.AbstractWatchService.poll(AbstractWatchService.java:108)
at org.apache.karaf.jaas.modules.properties.AutoEncryptionSupport.run(AutoEncryptionSupport.java:94)
"UDP-Receiver-0.0.0.0/0.0.0.0:5683[0]" Id=583 in RUNNABLE (running in native)
at java.base@11.0.15/java.net.PlainDatagramSocketImpl.receive0(Native Method)
- locked java.net.PlainDatagramSocketImpl@3c8600
at java.base@11.0.15/java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:200)
at java.base@11.0.15/java.net.DatagramSocket.receive(DatagramSocket.java:814)
- locked java.net.DatagramPacket@2287
- locked java.net.MulticastSocket@176baa4
at org.eclipse.californium.elements.UDPConnector$Receiver.work(UDPConnector.java:366)
at org.eclipse.californium.elements.UDPConnector$NetworkStageThread.run(UDPConnector.java:323)
"UDP-Sender-0.0.0.0/0.0.0.0:5683[0]" Id=584 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@be606b
at java.base@11.0.15/java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:433)
at org.eclipse.californium.elements.UDPConnector$Sender.work(UDPConnector.java:397)
"UDP-Receiver-0.0.0.0/0.0.0.0:0[0]" Id=623 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@6769e2
- locked java.net.DatagramPacket@1782587
- locked java.net.DatagramSocket@1388bab
"UDP-Sender-0.0.0.0/0.0.0.0:0[0]" Id=624 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@145a299
":CoapEndpoint-UDP-0.0.0.0:5683#1" Id=582 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@fbb3c2
":CoapEndpoint-UDP-0.0.0.0:0#1" Id=622 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@3d489
"main" Id=1 in WAITING on lock=java.util.concurrent.atomic.AtomicReference@12a6cdb
at org.eclipse.osgi.container.SystemModule.waitForStop(SystemModule.java:173)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.waitForStop(EquinoxBundle.java:312)
at org.eclipse.osgi.launch.Equinox.waitForStop(Equinox.java:217)
at app//org.apache.karaf.main.Main.awaitShutdown(Main.java:704)
at app//org.apache.karaf.main.Main.main(Main.java:193)
"Active Thread: Equinox Container: e5aac20a-2f34-4714-b721-2c8a2beab76d" Id=11 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1a715c9
"Framework Event Dispatcher: Equinox Container: e5aac20a-2f34-4714-b721-2c8a2beab76d" Id=13 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@1cbf052
at java.base@11.0.15/java.lang.Object.wait(Object.java:328)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:341)
"Bundle File Closer" Id=14 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@7a9095
"Start Level: Equinox Container: e5aac20a-2f34-4714-b721-2c8a2beab76d" Id=15 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@1b8b569
"Karaf Lock Monitor Thread" Id=16 in TIMED_WAITING
at java.base@11.0.15/java.lang.Thread.sleep(Native Method)
at app//org.apache.karaf.main.Main.doMonitor(Main.java:442)
at app//org.apache.karaf.main.Main.access$100(Main.java:78)
at app//org.apache.karaf.main.Main$3.run(Main.java:409)
"Karaf Shutdown Socket Thread" Id=17 in RUNNABLE (running in native)
at java.base@11.0.15/java.net.PlainSocketImpl.socketAccept(Native Method)
at java.base@11.0.15/java.net.AbstractPlainSocketImpl.accept(AbstractPlainSocketImpl.java:474)
at java.base@11.0.15/java.net.ServerSocket.implAccept(ServerSocket.java:565)
at java.base@11.0.15/java.net.ServerSocket.accept(ServerSocket.java:533)
at app//org.apache.karaf.main.ShutdownSocketThread.run(ShutdownSocketThread.java:66)
"EventAdminAsyncThread #11" Id=33 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1ec102f
"EventAdminAsyncThread #12" Id=34 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1ec102f
"fileinstall-/var/lib/openhab/etc" Id=42 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@d11802
"encryption-3-thread-1" Id=75 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@968133
"SCR Component Actor" Id=93 in WAITING on lock=java.util.LinkedList@10c2924
at org.apache.felix.scr.impl.ComponentActorThread.run(ComponentActorThread.java:83)
"openHAB Dir Watcher" Id=193 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c09e93
at java.base@11.0.15/sun.nio.fs.AbstractWatchService.take(AbstractWatchService.java:118)
at org.openhab.core.service.WatchQueueReader.run(WatchQueueReader.java:245)
"sshd-SshServer[1675623](port=8101)-timer-thread-1" Id=202 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@e46890
"EMF Reference Cleaner" Id=228 in WAITING on lock=java.lang.ref.ReferenceQueue$Lock@99f9e6
at java.base@11.0.15/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:155)
at java.base@11.0.15/java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:176)
at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
"OH-OSGiEventManager" Id=233 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@d0bed8
at java.base@11.0.15/java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:458)
at org.openhab.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:60)
at org.openhab.core.internal.events.ThreadedEventHandler$$Lambda$557/0x6eccec28.run(Unknown Source)
"OH-startlevel-1" Id=235 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@6e86d7
"ServletEventDispatcher: 1" Id=285 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@157d562
"ServletEventDispatcher: 2" Id=286 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@157d562
"ServletEventDispatcher: 3" Id=287 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@157d562
"Session-HouseKeeper-d00826-1" Id=290 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@9642a7
"qtp12496881-292-acceptor-0@1b34ad5-0.0.0.0:8443@9acd5f{SSL, (ssl, http/1.1)}{0.0.0.0:8443}" Id=292 in RUNNABLE (running in native)
at java.base@11.0.15/sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method)
at java.base@11.0.15/sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:533)
at java.base@11.0.15/sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:285)
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:388)
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:704)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
"qtp12496881-293" Id=293 in RUNNABLE (running in native)
at java.base@11.0.15/sun.nio.ch.EPoll.wait(Native Method)
at java.base@11.0.15/sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:120)
at java.base@11.0.15/sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:124)
- locked sun.nio.ch.Util$2@964a03
- locked sun.nio.ch.EPollSelectorImpl@77b98c
at java.base@11.0.15/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:141)
at org.eclipse.jetty.io.ManagedSelector.nioSelect(ManagedSelector.java:183)
at org.eclipse.jetty.io.ManagedSelector.select(ManagedSelector.java:190)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.select(ManagedSelector.java:606)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:543)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:362)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:186)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:137)
at org.eclipse.jetty.io.ManagedSelector$$Lambda$711/0x6d920828.run(Unknown Source)
"qtp12496881-294" Id=294 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@11f4609
- locked sun.nio.ch.EPollSelectorImpl@18a322a
"qtp12496881-295-acceptor-0@86cc93-default@1ae93ab{HTTP/1.1, (http/1.1)}{0.0.0.0:8080}" Id=295 in RUNNABLE (running in native)
"OH-karaf-addons-1" Id=340 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@9ad82a
"pool-12-thread-1" Id=375 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@176f5be
"SocketListener(192-168-12-162.local.)" Id=401 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@10dfd07
- locked java.net.DatagramPacket@ab4a66
- locked java.net.MulticastSocket@bab98e
at javax.jmdns.impl.SocketListener.run(SocketListener.java:57)
"SocketListener(192-168-12-101.local.)" Id=404 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@2b1cd3
- locked java.net.DatagramPacket@106a091
- locked java.net.MulticastSocket@e32fae
"SocketListener(192-168-12-215.local.)" Id=407 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@bb9875
- locked java.net.DatagramPacket@1845bd3
- locked java.net.MulticastSocket@69308a
"OH-eventexecutor-1" Id=410 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@30c347
"OH-eventwatcher-1" Id=411 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@114566b
"pool-6-thread-1" Id=412 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@f66f66
"OH-ruleengine-1" Id=421 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1270fb7
"OH-rule-plc_keepalive-1" Id=430 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@a3bf9f
"OH-lsp-1" Id=433 in RUNNABLE (running in native)
at org.openhab.core.model.lsp.internal.ModelServer.listen(ModelServer.java:105)
at org.openhab.core.model.lsp.internal.ModelServer.lambda$0(ModelServer.java:84)
at org.openhab.core.model.lsp.internal.ModelServer$$Lambda$953/0x6ad9d428.run(Unknown Source)
at java.base@11.0.15/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
"ServletModel-17-447" Id=447 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@13b805d
- locked sun.nio.ch.EPollSelectorImpl@1706166
"ServletModel-17-448" Id=448 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@1626740
- locked sun.nio.ch.EPollSelectorImpl@feca5e
"ServletModel-17-449" Id=449 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
at org.eclipse.jetty.util.BlockingArrayQueue.poll(BlockingArrayQueue.java:382)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.idleJobPoll(QueuedThreadPool.java:974)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1018)
"ServletModel-17-450" Id=450 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
"ServletModel-17-451" Id=451 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
"ServletModel-17-452" Id=452 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
"ServletModel-17-453" Id=453 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
"ServletModel-17-454" Id=454 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1668e34
"OH-scriptwatcher-1" Id=457 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@125a56f
"OH-rulesRefresher-1" Id=458 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1b39c2c
"OH-httpClient-common-469" Id=469 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@14315fe
- locked sun.nio.ch.EPollSelectorImpl@6b38cc
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
"OH-httpClient-common-470" Id=470 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@7bf8b3
- locked sun.nio.ch.EPollSelectorImpl@148466c
"OH-httpClient-common-471" Id=471 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@1d535e
- locked sun.nio.ch.EPollSelectorImpl@177adc9
"OH-httpClient-common-472" Id=472 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@9660f4
- locked sun.nio.ch.EPollSelectorImpl@14e25ac
"OH-httpClient-common-473" Id=473 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@17b0d38
at java.base@11.0.15/java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(SynchronousQueue.java:462)
at java.base@11.0.15/java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:361)
at java.base@11.0.15/java.util.concurrent.SynchronousQueue.poll(SynchronousQueue.java:937)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.reservedWait(ReservedThreadExecutor.java:324)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:399)
"OH-httpClient-common-474" Id=474 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@17b0d38
"OH-httpClient-common-475" Id=475 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@140eb3b
"OH-httpClient-common-476" Id=476 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@140eb3b
"OH-httpClient-common-477" Id=477 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@140eb3b
"OH-httpClient-common-478" Id=478 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@140eb3b
"JmDNS pool-13-thread-1" Id=479 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@a2a467
"JmDNS pool-14-thread-1" Id=480 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@d3929a
"JmDNS pool-15-thread-1" Id=481 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1c85f35
"Thread-71" Id=482 in TIMED_WAITING
at org.openhab.binding.shelly.internal.manager.ShellyManagerCache$CleanerThread.run(ShellyManagerCache.java:84)
"Thread-72" Id=483 in TIMED_WAITING
"Thread-73" Id=484 in TIMED_WAITING
"Thread-74" Id=485 in TIMED_WAITING
"Thread-75" Id=486 in TIMED_WAITING
"Thread-76" Id=487 in TIMED_WAITING
"Thread-77" Id=488 in TIMED_WAITING
"Thread-78" Id=489 in TIMED_WAITING
"Thread-79" Id=490 in TIMED_WAITING
"Thread-80" Id=491 in TIMED_WAITING
"Thread-81" Id=492 in TIMED_WAITING
"Thread-82" Id=493 in TIMED_WAITING
"OH-thingHandler-1" Id=528 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1256644
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:1218)
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:899)
at java.base@11.0.15/java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1053)
"OH-scriptwatcher-1" Id=530 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@31765b
"Thread-84" Id=551 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@190b488
- locked java.net.DatagramPacket@1c3e038
- locked java.net.DatagramSocket@31c0f5
at org.openhab.binding.network.internal.dhcp.DHCPPacketListenerServer.run(DHCPPacketListenerServer.java:101)
"OH-thingHandler-2" Id=552 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1256644
"OH-thingHandler-3" Id=553 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1256644
"OH-thingHandler-4" Id=555 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1256644
"OH-rule-network_siemens_logo_alive-1" Id=556 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1189972
"OH-thingHandler-5" Id=558 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1256644
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.poll(ScheduledThreadPoolExecutor.java:1223)
"HttpClient@670c9c-scheduler-1" Id=561 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1845ced
"OH-items-1" Id=562 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@130ae05
"OH-items-2" Id=563 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@130ae05
"OH-items-3" Id=564 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@130ae05
"OH-items-4" Id=565 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@130ae05
"OH-items-5" Id=566 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@130ae05
"OH-rule-alive_debounce-1" Id=567 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@190eebe
"OH-usb-serial-discovery-linux-sysfs-1" Id=571 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@a83837
"commons-pool-evictor-thread" Id=576 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@16e7e7b
"OH-modbusManagerPollerThreadPool-1" Id=577 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15abdd5
"OH-modbusManagerPollerThreadPool-2" Id=578 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15abdd5
"OH-rule-modbus_hvac_alive-1" Id=579 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15f4dde
"OH-rule-modbus_holding_alive_check-1" Id=585 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@7ce3fa
"OH-modbusManagerPollerThreadPool-3" Id=586 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15abdd5
"OH-modbusManagerPollerThreadPool-4" Id=587 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15abdd5
"OH-rule-modbus_coil_alive_check-1" Id=588 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1cbfda8
"OH-modbusManagerPollerThreadPool-5" Id=589 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@15abdd5
"OH-rule-system_uptime-1" Id=593 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@138c02f
"OH-httpClient-openhabcloud-597" Id=597 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@3e4bdb
- locked sun.nio.ch.EPollSelectorImpl@13c02d5
"OH-httpClient-openhabcloud-598" Id=598 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@1608c27
- locked sun.nio.ch.EPollSelectorImpl@ea171c
"OH-httpClient-openhabcloud-599" Id=599 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b6e889
"OH-httpClient-openhabcloud-600" Id=600 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b6e889
"OH-httpClient-openhabcloud-601" Id=601 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b6e889
"OkHttp ConnectionPool" Id=607 in TIMED_WAITING on lock=okhttp3.ConnectionPool@1d363a0
at java.base@11.0.15/java.lang.Object.wait(Object.java:462)
at okhttp3.ConnectionPool$1.run(ConnectionPool.java:67)
"Okio Watchdog" Id=608 in TIMED_WAITING on lock=java.lang.Class@1592ba9
at okio.AsyncTimeout.awaitTimeout(AsyncTimeout.java:361)
at okio.AsyncTimeout$Watchdog.run(AsyncTimeout.java:312)
"OH-rule-update_openhab_items_to_modbus_regular-1" Id=625 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@a4fa6a
"OH-rule-jvm_stats-1" Id=626 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2ea3a4
"sdk-ScheduledExecutor-1-1" Id=634 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@11e1e59
at java.base@11.0.15/java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1177)
"sdk-ScheduledExecutor-1-0" Id=636 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@11e1e59
"sdk-ScheduledExecutor-1-2" Id=635 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@11e1e59
"sdk-ScheduledExecutor-1-3" Id=637 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@11e1e59
"sdk-ScheduledExecutor-1-4" Id=638 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@11e1e59
"aws-java-sdk-NettyEventLoop-0-0" Id=639 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@1292489
- locked sun.nio.ch.EPollSelectorImpl@fbf4ac
at io.netty.channel.nio.SelectedSelectionKeySetSelector.select(SelectedSelectionKeySetSelector.java:68)
at io.netty.channel.nio.NioEventLoop.select(NioEventLoop.java:813)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:460)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:986)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
"aws-java-sdk-NettyEventLoop-0-2" Id=641 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@131b017
- locked sun.nio.ch.EPollSelectorImpl@8bbea2
"aws-java-sdk-NettyEventLoop-0-1" Id=640 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@722324
- locked sun.nio.ch.EPollSelectorImpl@1e6554e
at java.base@11.0.15/sun.nio.ch.SelectorImpl.select(SelectorImpl.java:136)
at io.netty.channel.nio.SelectedSelectionKeySetSelector.select(SelectedSelectionKeySetSelector.java:62)
at io.netty.channel.nio.NioEventLoop.select(NioEventLoop.java:817)
"aws-java-sdk-NettyEventLoop-0-3" Id=642 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@df199c
- locked sun.nio.ch.EPollSelectorImpl@194d43f
"aws-java-sdk-NettyEventLoop-0-4" Id=643 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@1e15dd4
- locked sun.nio.ch.EPollSelectorImpl@f47b27
"aws-java-sdk-NettyEventLoop-0-5" Id=644 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@1b1d0d4
- locked sun.nio.ch.EPollSelectorImpl@b6b5c9
"aws-java-sdk-NettyEventLoop-0-6" Id=645 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@3709c0
- locked sun.nio.ch.EPollSelectorImpl@126daca
"aws-java-sdk-NettyEventLoop-0-7" Id=646 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@fc938a
- locked sun.nio.ch.EPollSelectorImpl@17965e1
"OH-rule-webcam_restart-1" Id=648 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1a015c7
"RxSchedulerPurge-1" Id=663 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@117b73
"RxCachedWorkerPoolEvictor-1" Id=664 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@fc4f8
"com.hivemq.client.mqtt-2-1" Id=666 in RUNNABLE (running in native)
- locked io.netty.channel.nio.SelectedSelectionKeySet@95ec75
- locked sun.nio.ch.EPollSelectorImpl@13cc50d
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30)
"pool-2-thread-1" Id=675 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@114e536
"OH-rule-update_openhab_items_to_modbus-1" Id=676 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1f9a164
"OH-rule-kitchen_sink_alive_check-1" Id=680 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1667eb5
"OH-rule-KitchenSinkFloodDetectorStatusCheck-1" Id=681 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1ae174d
"OH-rule-kitchen_dishwasher_alive_check-1" Id=682 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1e37c1b
"OH-rule-estimate_power_cuts-1" Id=684 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1dd02c2
"RXTXPortMonitor(/dev/ttyUSBzwave)" Id=687 in RUNNABLE
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:108)
"ZWaveReceiveInputThread" Id=688 in RUNNABLE
at gnu.io.RXTXPort.readByte(Native Method)
at gnu.io.RXTXPort$SerialInputStream.read(RXTXPort.java:1344)
- locked gnu.io.RXTXPort$SerialInputStream@13c531a
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.run(ZWaveSerialHandler.java:322)
"ZWaveReceiveProcessorThread" Id=690 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@3092b8
at java.base@11.0.15/java.util.concurrent.ArrayBlockingQueue.take(ArrayBlockingQueue.java:417)
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$ZWaveReceiveThread.run(ZWaveTransactionManager.java:474)
"Connector-Scheduler-9acd5f-1" Id=818 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1b652ee
"OkHttp https://myopenhab.org/..." Id=1785 in RUNNABLE (running in native)
at java.base@11.0.15/java.net.SocketInputStream.socketRead0(Native Method)
at java.base@11.0.15/java.net.SocketInputStream.socketRead(SocketInputStream.java:115)
at java.base@11.0.15/java.net.SocketInputStream.read(SocketInputStream.java:168)
at java.base@11.0.15/java.net.SocketInputStream.read(SocketInputStream.java:140)
at java.base@11.0.15/sun.security.ssl.SSLSocketInputRecord.read(SSLSocketInputRecord.java:478)
at java.base@11.0.15/sun.security.ssl.SSLSocketInputRecord.readHeader(SSLSocketInputRecord.java:472)
at java.base@11.0.15/sun.security.ssl.SSLSocketInputRecord.bytesInCompletePacket(SSLSocketInputRecord.java:70)
at java.base@11.0.15/sun.security.ssl.SSLSocketImpl.readApplicationRecord(SSLSocketImpl.java:1454)
at java.base@11.0.15/sun.security.ssl.SSLSocketImpl$AppInputStream.read(SSLSocketImpl.java:1065)
at okio.Okio$2.read(Okio.java:139)
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237)
at okio.RealBufferedSource.request(RealBufferedSource.java:67)
at okio.RealBufferedSource.require(RealBufferedSource.java:60)
at okio.RealBufferedSource.readByte(RealBufferedSource.java:73)
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:113)
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:97)
at okhttp3.internal.ws.RealWebSocket.loopReader(RealWebSocket.java:262)
at okhttp3.internal.ws.RealWebSocket$2.onResponse(RealWebSocket.java:201)
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:141)
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32)
"pool-458-thread-1" Id=1932 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1c77e50
"OkHttp WebSocket https://myopenhab.org/..." Id=1938 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@12a89c2
"OH-rule-check_water_sensor_status_after_restart-1" Id=7091 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@38836b
"ZWaveNode1Init2022-10-21 02:05:21.079" Id=89455 in WAITING on lock=java.util.concurrent.FutureTask@ccddb4
at java.base@11.0.15/java.util.concurrent.FutureTask.awaitDone(FutureTask.java:447)
at java.base@11.0.15/java.util.concurrent.FutureTask.get(FutureTask.java:190)
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.sendTransaction(ZWaveTransactionManager.java:1205)
at org.openhab.binding.zwave.internal.protocol.ZWaveController.sendTransaction(ZWaveController.java:548)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:292)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.processTransaction(ZWaveNodeInitStageAdvancer.java:265)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer.doHealStages(ZWaveNodeInitStageAdvancer.java:1118)
at org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer$1.run(ZWaveNodeInitStageAdvancer.java:185)
"ZWaveTransactionManager-9" Id=89458 in WAITING on lock=org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter@533f1d
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter.call(ZWaveTransactionManager.java:1134)
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter.call(ZWaveTransactionManager.java:1)
"qtp12496881-133965" Id=133965 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@ab063b
- locked sun.nio.ch.EPollSelectorImpl@a28146
"qtp12496881-133975" Id=133975 in RUNNABLE (running in native)
- locked sun.nio.ch.Util$2@35dadb
- locked sun.nio.ch.EPollSelectorImpl@16bb797
"ZWaveNode20Init2022-10-22 02:05:21.081" Id=141312 in WAITING on lock=java.util.concurrent.FutureTask@163e814
"ZWaveNode21Init2022-10-22 02:05:21.087" Id=141313 in WAITING on lock=java.util.concurrent.FutureTask@1a201a1
"ZWaveTransactionManager-14" Id=141314 in WAITING on lock=org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter@151d50d
"ZWaveTransactionManager-15" Id=141316 in WAITING on lock=org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager$1TransactionWaiter@114defc
"OH-safeCall-349" Id=152624 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@16bb542
"OH-safeCall-350" Id=152696 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@16bb542
"OH-scheduler-1690" Id=152844 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b51887
"OH-safeCall-351" Id=153152 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@16bb542
"OH-scheduler-1699" Id=154088 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b51887
"OH-dynamodbPersistenceService-3914" Id=154118 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1875961
"OH-common-6292" Id=154149 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c59893
"OH-discovery-7874" Id=154212 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f46c
"OH-common-6295" Id=154218 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c59893
"OH-scheduler-1701" Id=154234 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b51887
"OH-scheduler-1702" Id=154267 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b51887
"OH-scheduler-1703" Id=154271 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@b51887
"OH-common-6297" Id=154290 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c59893
"OH-dynamodbPersistenceService-3917" Id=154303 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@1875961
"OH-discovery-7882" Id=154352 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f46c
"OH-common-6300" Id=154362 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c59893
"OH-discovery-7883" Id=154367 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f46c
"OH-discovery-7884" Id=154374 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f46c
"OH-common-6301" Id=154375 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@c59893
"OH-discovery-7885" Id=154402 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@2f46c
"sshd-SshServer[1675623](port=8101)-nio2-thread-1" Id=154403 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@f1ad0b
"sshd-SshServer[1675623](port=8101)-nio2-thread-2" Id=154404 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@f1ad0b
"items-queue" Id=154405 in TIMED_WAITING on lock=java.util.concurrent.LinkedTransferQueue@166a8a5
at java.base@11.0.15/java.util.concurrent.LinkedTransferQueue.awaitMatch(LinkedTransferQueue.java:740)
at java.base@11.0.15/java.util.concurrent.LinkedTransferQueue.xfer(LinkedTransferQueue.java:684)
at java.base@11.0.15/java.util.concurrent.LinkedTransferQueue.poll(LinkedTransferQueue.java:1374)
at org.openhab.core.common.QueueingThreadPoolExecutor$1.run(QueueingThreadPoolExecutor.java:193)
"Thread-20734" Id=154406 in WAITING on lock=org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@10baada
at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.start(CommandSessionImpl.java:802)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:300)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:169)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:149)
at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:179)
at org.apache.karaf.shell.impl.console.HeadlessSessionImpl.execute(HeadlessSessionImpl.java:113)
at org.apache.karaf.shell.ssh.ShellCommand.lambda$run$0(ShellCommand.java:115)
at org.apache.karaf.shell.ssh.ShellCommand$$Lambda$2564/0x60e0e428.run(Unknown Source)
at java.base@11.0.15/java.security.AccessController.doPrivileged(Native Method)
at org.apache.karaf.util.jaas.JaasHelper.doAs(JaasHelper.java:116)
at org.apache.karaf.shell.ssh.ShellCommand.run(ShellCommand.java:109)
at org.apache.karaf.shell.ssh.ShellCommand$$Lambda$2563/0x622ecc28.run(Unknown Source)
"job controller 1" Id=154407 in WAITING on lock=java.util.concurrent.FutureTask@fb9143
at java.base@11.0.15/java.util.concurrent.AbstractExecutorService.invokeAll(AbstractExecutorService.java:247)
at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.run(CommandSessionImpl.java:827)
"pipe-threads" Id=154408 in RUNNABLE
at java.management@11.0.15/sun.management.ThreadImpl.dumpThreads0(Native Method)
at java.management@11.0.15/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:521)
at java.management@11.0.15/sun.management.ThreadImpl.dumpAllThreads(ThreadImpl.java:509)
at org.apache.karaf.shell.commands.impl.ThreadsAction.execute(ThreadsAction.java:78)
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86)
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599)
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415)
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59)
"session-1-thread-3" Id=154409 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@12bf9e2
"session-1-thread-4" Id=154410 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@12bf9e2
"Common-Cleaner" Id=9 in TIMED_WAITING on lock=java.lang.ref.ReferenceQueue$Lock@368032
at java.base@11.0.15/jdk.internal.ref.CleanerImpl.run(CleanerImpl.java:148)
at java.base@11.0.15/jdk.internal.misc.InnocuousThread.run(InnocuousThread.java:161)
"process reaper" Id=550 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@786cc5
"process reaper" Id=557 in TIMED_WAITING on lock=java.util.concurrent.SynchronousQueue$TransferStack@786cc5
</p>
</details>
hajeth
(Thomas)
October 30, 2022, 12:32pm
27
I do not use MQTT
Bundles list:
START LEVEL 100 , List Threshold: 50
ID β State β Lvl β Version β Name
βββββΌβββββββββΌββββββΌβββββββββββββββββββββββββΌββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
29 β Active β 80 β 2.12.6 β Jackson-annotations
30 β Active β 80 β 2.12.6 β Jackson-core
31 β Active β 80 β 2.12.6.1 β jackson-databind
32 β Active β 80 β 2.12.6 β Jackson-dataformat-YAML
33 β Active β 80 β 2.12.6 β Jackson datatype: JSR310
34 β Active β 80 β 6.2.6 β Woodstox
35 β Active β 80 β 2.8.9 β Gson
36 β Active β 80 β 30.1.0.jre β Guava: Google Core Libraries for Java
37 β Active β 80 β 1.0.1 β Guava InternalFutureFailureAccess and InternalFutures
38 β Active β 80 β 5.0.1.v20210324-2015 β Google Guice - Core Library
40 β Active β 80 β 4.8.138.v20211212-1642 β ClassGraph
41 β Active β 80 β 2.1.9 β swagger-annotations
42 β Active β 80 β 2.1.9 β swagger-core
43 β Active β 80 β 2.1.9 β swagger-integration
44 β Active β 80 β 2.1.9 β swagger-jaxrs2
45 β Active β 80 β 2.1.9 β swagger-models
46 β Active β 80 β 2.0.2 β Jakarta Bean Validation API
48 β Active β 80 β 2.3.3 β Jakarta XML Web Services API
51 β Active β 80 β 3.5.8 β JmDNS
52 β Active β 80 β 2.1.3 β Units of Measurement API
54 β Active β 80 β 0.5.10 β Jollyday
55 β Active β 80 β 3.2.0.v201101311130 β ANTLR Runtime
56 β Active β 80 β 1.0.0.v201105210816 β Aopalliance Plug-in
57 β Active β 80 β 1.2.2 β org.apache.aries.component-dsl.component-dsl
58 β Active β 80 β 1.0.1 β Apache Aries JAX-RS Specification API
59 β Active β 80 β 2.0.0 β Apache Aries JAX-RS Whiteboard
61 β Active β 80 β 3.12.0 β Apache Commons Lang
62 β Active β 80 β 3.4.5 β Apache CXF Core
63 β Active β 80 β 3.4.5 β Apache CXF Runtime JAX-RS Frontend
64 β Active β 80 β 3.4.5 β Apache CXF JAX-RS Client
65 β Active β 80 β 3.4.5 β Apache CXF JAX-RS Server-Side Events Support
66 β Active β 80 β 3.4.5 β Apache CXF Runtime Security functionality
67 β Active β 80 β 3.4.5 β Apache CXF Runtime HTTP Transport
75 β Active β 80 β 4.3.7 β Apache Karaf :: OSGi Services :: Event
86 β Active β 80 β 1.0.0.2 β Apache ServiceMix :: Bundles :: javax.inject
94 β Active β 80 β 2.2.5 β XmlSchema Core
95 β Active β 80 β 4.21.0 β Apache XBean :: OSGI Bundle Utilities
96 β Active β 80 β 4.21.0 β Apache XBean :: Classpath Resource Finder
97 β Active β 80 β 0.7.7 β jose4j
98 β Active β 80 β 2.17.0.v20190920-0401 β EMF Common
99 β Active β 80 β 2.20.0.v20190920-0401 β EMF Ecore
100 β Active β 80 β 2.14.0.v20190528-0725 β EMF Change Model
101 β Active β 80 β 2.16.0.v20190528-0725 β EMF XML/XMI Persistence
102 β Active β 80 β 3.13.0.v20200828-1034 β Common Eclipse Runtime
130 β Active β 80 β 0.12.0.v20210402-1305 β org.eclipse.lsp4j
131 β Active β 80 β 0.12.0.v20210402-1305 β org.eclipse.lsp4j.jsonrpc
132 β Active β 80 β 2.26.0.v20220228-0748 β Xtend Runtime Library
133 β Active β 80 β 2.26.0.v20220228-0748 β Xtend Macro Interfaces
134 β Active β 80 β 2.26.0.v20220228-0751 β Xtext
135 β Active β 80 β 2.26.0.v20220228-0758 β Xtext Common Types
136 β Active β 80 β 2.26.0.v20220228-0751 β Xtext IDE Core
137 β Active β 80 β 2.26.0.v20220228-0751 β Xtext Utility
138 β Active β 80 β 2.26.0.v20220228-0758 β Xbase Model
139 β Active β 80 β 2.26.0.v20220228-0758 β Xbase Generic IDE Services
140 β Active β 80 β 2.26.0.v20220228-0748 β Xbase Runtime Library
144 β Active β 80 β 9.2.0 β org.objectweb.asm.commons
145 β Active β 80 β 9.2.0 β org.objectweb.asm.tree
146 β Active β 80 β 9.2.0 β org.objectweb.asm.tree.analysis
147 β Active β 80 β 9.2.0 β org.objectweb.asm.util
148 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Core
149 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Marketplace Add-on Services
150 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Community Marketplace Add-on Service :: Karaf
151 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Audio
152 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: JAAS Authentication
153 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: OAuth2Client
154 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Automation
155 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Automation Media Modules
156 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Automation Script Modules
157 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Automation Script RuleSupport
158 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Automation REST API
159 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Binding XML
160 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration Core
161 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration Discovery
162 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration mDNS Discovery
163 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration Dispatcher
164 β Active β 75 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration XML
165 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Ephemeris
166 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: ID
167 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Console
168 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Console for OSGi runtime Karaf
169 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: HTTP Interface
170 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: HTTP Interface Authentication
172 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Monitor
173 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Network I/O
174 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: REST Interface
175 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Audio REST Interface
176 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Authentication Support for the REST Interface
177 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: REST Interface :: Core
178 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: REST mDNS Announcer
179 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Sitemap REST Interface
180 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: SSE Interface
181 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: REST Interface :: Swagger 1
182 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Transformation REST Interface
183 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: UI REST Interface
184 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Voice REST Interface
185 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: mDNS Service
186 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Karaf Integration
187 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Core
188 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Items
189 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Item IDE
190 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Items Runtime
191 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Language Server
192 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Persistence
193 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Persistence IDE
194 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Persistence Runtime
195 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Rules
196 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Rule IDE
197 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Rules Runtime
198 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Script
199 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Script IDE
200 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Script Runtime
201 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Sitemap
202 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Sitemap IDE
203 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Sitemap Runtime
204 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Thing
205 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Thing IDE
206 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Model Thing Runtime
207 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Persistence
208 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Semantics
209 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: JSON Storage
210 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Thing
211 β Active β 75 β 3.4.0.M2 β openHAB Core :: Bundles :: Thing XML
212 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Transformation Service
213 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: UI
214 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: UI Icon Support
215 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Voice
216 β Active β 80 β 3.4.0.M2 β openHAB UI :: Bundles :: Main UI
217 β Active β 80 β 3.4.0.M2 β openHAB UI :: Bundles :: Icon Set :: Classic
224 β Active β 80 β 1.0.0.201802012106 β org.osgi:org.osgi.service.jaxrs
225 β Active β 80 β 1.5.0 β ThreeTen-Extra
226 β Active β 80 β 1.27.0 β SnakeYAML
227 β Active β 80 β 2.1 β SI Units
228 β Active β 80 β 2.1.0 β SI Quantities
229 β Active β 80 β 4.2.1 β Stax2 API
230 β Active β 80 β 2.1.2 β Units of Measurement Reference Implementation
231 β Active β 80 β 2.1.0 β Units of Measurement Common Library for Java
232 β Active β 80 β 1.4.19 β XStream Core
233 β Active β 80 β 1.6.2 β JavaMail API
234 β Active β 80 β 3.7.2 β Apache Commons Net
235 β Active β 80 β 2.6.1 β JUPnP Library
236 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Exec Binding
237 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Gardena Binding
238 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Homematic Binding
239 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Kodi Binding
240 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Mail Binding
241 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Network Binding
242 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Velux Binding
243 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: Configuration UPnP Discovery
244 β Active β 80 β 3.4.0.M2 β openHAB Core :: Bundles :: UPnP Transport
245 β Active β 80 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Persistence Service :: RRD4j
246 β Active β 75 β 3.4.0.M2 β openHAB Add-ons :: Bundles :: Transformation Service :: RegEx
247 β Active β 80 β 3.4.0.M2 β openHAB UI :: Bundles :: Basic UI
248 β Active β 80 β 3.4.0.M2 β openHAB UI :: Bundles :: HABPanel UI
Lolodomo
(Lolodomo)
November 1, 2022, 8:28am
28
I would suggest to start by stopping the homematic binding to see if it solves your problem.
hajeth
(Thomas)
November 1, 2022, 11:23am
29
No the problem has occured again.
At this time again there was a log entry from Kodi binding before the Gardena binding showed the connection timeouts.
2022-11-01 08:26:26.151 [TRACE] [rdena.internal.GardenaSmartWebSocket] - Pong received (Gardena_Account-My Garden)
2022-11-01 08:28:15.566 [INFO ] [org.openhab.core.model.script.Test ] - Kodi Wohnzimmer OFFLINE
2022-11-01 08:28:56.157 [DEBUG] [rdena.internal.GardenaSmartWebSocket] - Gardena Webservice error (Gardena_Account-My Garden)
org.eclipse.jetty.websocket.api.CloseException: java.util.concurrent.TimeoutException: Idle timeout expired: 150005/150000 ms
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onReadTimeout(AbstractWebSocketConnection.java:564) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection.onFillInterestedFailed(AbstractConnection.java:172) ~[?:?]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillInterestedFailed(AbstractWebSocketConnection.java:539) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.failed(AbstractConnection.java:317) ~[?:?]
at org.eclipse.jetty.io.FillInterest.onFail(FillInterest.java:140) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillableFail(SslConnection.java:591) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillInterestedFailed(SslConnection.java:419) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.failed(SslConnection.java:170) ~[?:?]
at org.eclipse.jetty.io.AbstractEndPoint.onIdleExpired(AbstractEndPoint.java:407) ~[?:?]
at org.eclipse.jetty.io.IdleTimeout.checkIdleTimeout(IdleTimeout.java:171) ~[?:?]
at org.eclipse.jetty.io.IdleTimeout.idleCheck(IdleTimeout.java:113) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) [?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.util.concurrent.TimeoutException: Idle timeout expired: 150005/150000 ms
... 8 more
First i will test to disable the Kodi binding and see if the error appears again.
As requested: threads --monitors --locks when the error occured
Thread_locks.txt (203.3 KB)
Alf
(Alf Pfeiffer)
November 9, 2022, 8:26am
30
Interesting theory, I will try this at once. As I mention in my previous post, my issue was related to the RFCOM-binding(I thought). Since then Iβve uninstalled the Gardena binding and am concluding two things.
Serious hang (entire system) has not happended
RFXCOM binding still hangs.
Iβve finally identified and fixed the RFXCOM issue, probably related to a faulty power plug switch which I replaced and problem disappeard.
So I will now reinstall the Gardena binding, keep an eye of the treads.
PS. I do use non-official bindings
hajeth
(Thomas)
November 13, 2022, 1:20pm
31
Update:
No hangs or problems since Kodi binding was removed.
@AndrewFG : Seems your guess was correct. Even there was a hang without an log entry from the Kodi binding, since it was uninstalled all is working ok now. Maybe the binding crashed and the corresponding log entry could not get logged.
