Dear Everybody,
My Environment
Platform information:
Hardware: Raspberry Pi 3 Model B+
OS: OpenHABian (2.3.0-1)
openHAB version: 2.3.0-1
Extension:
Gardena Smart Home Binding
After setting up image of openhabian and installation of Gardena Smart Home binding I tried to create the things.
In Gardena smart system you can configure things from partners Netatmo Presence & Husqvarna Automower. These were successfuly connected and are working with Smart Gardena.
If I install the Gardena Smart Home Binding the things to be configured appear in the inbox after first creating the thing “Gardena Smart Home Account”. Also the Husqvarna Automower & Netatmo Presence things are appearing in the inbox. After successfully creating the things the thing “Gardena Smart Home Account” goes offline as well as the thing “Automower”. The error that appears in the log is as follows:
2018-07-14 07:51:10.268 [ERROR] [ardena.handler.GardenaAccountHandler] - There is something wrong with your thing ‘gardena:mower:bdf199b9:984ff564-7883-1234-1234-123456789012’, please check or recreate it: Property ‘sgtin’ not found in ability ‘device_info’
So the Husqvarna is configured as ‘gardena:mower’ and it seems that it expects some other parameters.
If I add a item the current state e.g. battery level is shown in the control view if the paperUI.
But it does not show the most updated values because it could be that the thing is offline…
Is there any workaround or any other possibility to connect?
Thanks ahead!
