Binding for Garmin inReach satellite communicators via MapShare KML feed. Track real-time GPS position, speed, elevation, course, and message events — even when off-grid on the Iridium satellite network.
More:
Integrates any Garmin inReach device with openHAB by polling the free MapShare KML feed over HTTPS. No API key required — just your MapShare identifier. Works with inReach Mini/Mini 2, Explorer/Explorer+, GPSMAP 66i/67i/86sci, Montana 700i/750i, and Garmin Messenger.
Use Cases
- Live motorcycle/vehicle trip tracking via satellite
- Hiking & adventure tracking with no cellular dependency
- Emergency SOS monitoring with instant home automation triggers
- Remote asset tracking in areas without cellular coverage
- Combined with cellular GPS (e.g. Teltonika FMM) for hybrid tracking
Channels
| Channel | Type | Description |
position |
Location | GPS coordinates (lat, lon, elevation) |
lastUpdate |
DateTime | Timestamp of last satellite report |
speed |
Number:Speed | Ground speed |
course |
Number:Angle | Heading / bearing |
elevation |
Number:Length | Altitude above sea level |
event |
String | Event type (e.g. Tracking, SOS) |
gpsFix |
Switch | Whether GPS has a valid fix |
emergency |
Switch | SOS/emergency state |
text |
String | inReach message text |
trackingActive |
Switch | Whether active tracking is on |
distance |
Number:Length | Distance from home/reference |
Configuration
| Parameter | Type | Required | Default | Description |
mapShareId |
String | Yes | — | Your MapShare identifier from share.garmin.com |
password |
String | No | — | MapShare password if feed is protected |
refreshInterval |
Integer | No | 120 | Poll interval in seconds |
historyHours |
Integer | No | 24 | Hours of track history to fetch |
Prerequisites
- A Garmin inReach device with an active satellite subscription
- MapShare enabled at share.garmin.com
- Note your MapShare identifier from the MapShare URL
Quick Start
Thing:
Thing inreach:tracker:mytracker "My inReach" [ mapShareId="YourMapShareID", refreshInterval=120, historyHours=24 ]
Items:
Location InReach_Position "Position" { channel="inreach:tracker:mytracker:position" }
DateTime InReach_LastUpdate "Last Update" { channel="inreach:tracker:mytracker:lastUpdate" }
Number:Speed InReach_Speed "Speed" { channel="inreach:tracker:mytracker:speed" }
Number:Angle InReach_Course "Course" { channel="inreach:tracker:mytracker:course" }
Number:Length InReach_Elevation "Elevation" { channel="inreach:tracker:mytracker:elevation" }
String InReach_Event "Event" { channel="inreach:tracker:mytracker:event" }
Switch InReach_Emergency "Emergency" { channel="inreach:tracker:mytracker:emergency" }
String InReach_Text "Message" { channel="inreach:tracker:mytracker:text" }
Switch InReach_Tracking "Tracking Active" { channel="inreach:tracker:mytracker:trackingActive" }
Number:Length InReach_Distance "Distance from Home" { channel="inreach:tracker:mytracker:distance" }
Example Rule — Emergency Alert:
rules.JSRule({
name: "InReach SOS Alert",
triggers: [triggers.ItemStateChangeTrigger("InReach_Emergency", undefined, "ON")],
execute: () => {
actions.NotificationAction.sendNotification("admin@home.local", "🚨 EMERGENCY SOS activated on inReach!");
How It Works
The binding polls the Garmin MapShare KML feed at your configured interval. MapShare is a free Garmin service that exposes your inReach device’s position and messages as a KML/XML feed over HTTPS. The feed is updated each time the device sends a satellite report (typically every 2–10 minutes depending on your tracking interval).
Known Quirks
- Satellite latency — inReach reports arrive with ~30–90 second delay via Iridium
- Feed caching — Garmin’s MapShare servers may cache data for 1–2 minutes
- UTF-8 BOM — The binding handles Garmin’s non-standard BOM in KML responses
- Poll-based — No real-time push; set
refreshIntervalto balance freshness vs. server load
Changelog
Version 1.0.0
- Initial release
- 11 channels: position, speed, course, elevation, events, SOS, messages, tracking state, distance
- MapShare KML feed polling via Iridium satellite network
- Optional password-protected feed support
- Configurable poll interval and history window
- UTF-8 BOM handling for Garmin’s non-standard KML
- Developed and tested with openHAB 5.x
Resources
Developed by @Prinsessen — Licensed under EPL-2.0
