Perhaps it is related to the load due to the Alexa skill release, but I can´t access the myopenhab-service right now and only see an “504 gateway timeout” error-page.
Same Problem here and i thought it was my Router.
You can see this on http://status.openhab.org/ too.
Oh and now the status page says that is all is ok but it dosnt work.
Yes, something isn’t working. Kind of annoying when just playing around with the alexa-skill. Hopefully it will be restored, soon.
Yepp, same problem here, although openHABcloud is online …
Did you get anywhere with this?
I am experiencing the same thing, do I need to make any changes on my router?
Thanks,
Col
No, still the same annoying outages …
I don’t think you need to change your setup or your router config, it’s just an outage on a free cloud service
Thanks @sihui for the reply, I worked that out as more and more services including this community went offline.
I couldn’t post my follow up to say I had confirmed I didnt need to open anything up on my router.
I just have bad timing, over the past few weeks I have set-aside a few evenings to play with this and each time I have hit similar issues. I managed to get it up and running eventually, I just cant login to the alexa skill now.
Thanks again,
Col
