I have a GoControl GC-TBZ48 Thermostat that generally works well. I was looking at the “thing configuration parameters” and noticed parameters 43/46 which allow for a remote sensor node/temperature to be set. I’ve always been curious about using multiple sensors to read temperatures around the house and this seems like it’ll be a good way to integrate it.
Being that its just 1 node value that it allows and I may have multiple, and the other sensors aren’t going to be zwave but most likely zigbee/matter devices, it wont quite work using the node id value. I see that it might be possible to set thing parameters from a rule (will take average for example) using the rest endpoint (seems kinda ugly). Is there a newer/better way to do this? Is it frowned upon to constantly update parameter values? Here’s the AI remote regarding the sensor setpoint:
GoControl GC-TBZ48 Remote Sensor Configuration
The GC-TBZ48 supports using an external remote temperature sensor by configuring two key Z-Wave parameters:
Parameter 43: Remote Sensor 1 Node Number
Set this to 1 to enable the use of a remote temperature sensor. This tells the thermostat to expect temperature data from a specific device on the network.Parameter 46: Remote Sensor 1 Temperature
This parameter receives the actual temperature value from the remote sensor. To keep the thermostat using the remote temperature instead of its internal sensor, you must update this value at least once every 5 minutes. If not updated, the thermostat reverts to using its internal temperature reading.Note: This feature is not documented in the official user manual but is confirmed functional in smart home platforms like Home Assistant (via Z-Wave JS) and Hubitat. Automation scripts can be used to send the average temperature from multiple sensors (e.g., a whole-home average) to Parameter 46.
