Yesterday I installed the GCAL Binding org.openhab.io.gcal-1.9.0-SNAPSHOT.jar on Openhab Runtime 1.8.3 and configured Google API. all was working fine after initial setup and I was successfully able to execute command based on calendar scheduling.
after a few hours, GCAL Binding stopped working and does not come back even if I restart Openhab. it always. on start and on every refresh (15min default), I can see the following error in Openhab.log
2016-12-25 11:06:23.290 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Google Calender Event-Downloader
at org.openhab.io.gcal.internal.GCalEventDownloader.processEntries(GCalEventDownloader.java:340) ~[na:na]
at org.openhab.io.gcal.internal.GCalEventDownloader.execute(GCalEventDownloader.java:182) ~[na:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) ~[na:na]
does anybody has an idea how to fix this ? I really loved the gCAL Binding even though it was just working for a few hours.
Hello, I think itās odd that the stack trace does not agree with the current code on the master branch. Would you mind double-checking that you are using the latest JAR and report back here?
Are you totally sure you only have one io.gcal JAR in your addons folder? Sorry to ask again, because the given stack trace canāt come from latest code (best I can tell).
Do i need to store the .JSON file from Google and store it somewhere in the openhab Folders ?
or can I force the initialization process once again and start from stretch with the latest .jar you provided ?
unfortunatelly, I never managed to Telnet into osgi console. when ever i telnet to localhost on port 555, I got a root@nuc01:~# telnet localhost 5555
Trying 127.0.0.1ā¦
telnet: Unable to connect to remote host: Connection refused
I also have the -console=5555 in the start.sh but it does not help.
Something seems odd about your openHAB 1.8.3 installation. Is there a reason you did not install using the apt-get method (which puts files in /etc/openhab, /usr/share/openhab, /var/log/openhab, etc.)?
i found it more easy to have it running as runtime. I can easelly do a backup of the whole Folder and re-install (copy back) if something goes wrong with Ubuntu or Openhab. Since Iām not really the Unix expert, I could not really troubleshoot if apt-get does something I donāt like.
beside the gcal issue, openhab runs absolutelly fine without any isse. I had it on 1.7 since at least 2 years without any Problem and upgraded recently to 1.8.3 without any Problem. it is really just the gcal causing Problems.
John,
can I somehow force a new registration with Google ? i.e. can I somehow force to repeat the following steps ?
I wonder if the issue is because I did not open the URL below on the openhab machine but on my PC i remotly managed the Openhab.
[INFO ] [g.internal.GCalEventDownloader] - # Google-Integration: U S E R I N T E R A C T I O N R E Q U I R E D !!
[INFO ] [g.internal.GCalEventDownloader] - # 1. Open URL āhttps://www.google.com/deviceā
[INFO ] [g.internal.GCalEventDownloader] - # 2. Type provided code ZPWT-UVXXS
[INFO ] [g.internal.GCalEventDownloader] - # 3. Grant openHAB access to your Google calendar
[INFO ] [g.internal.GCalEventDownloader] - # 4. openHAB will automatically detect the permiossions and complete the authentication process
[INFO ] [g.internal.GCalEventDownloader] - # NOTE: You will only have 1800 mins before openHAB gives up waiting for the access!!!
[INFO ] [g.internal.GCalEventDownloader] -################################################################################################
On openHAB 1.8.3 using the apt-get installation, the credentials appear to be stored in /var/lib/openhab/gcal/gcal_oauth2_token. On other versions or operating systems, search for the file gcal_oauth2_token. I think if you back it up, delete it, and restart openHAB, it should go through the process again. Please report back with your observations and thanks.
thanks to your hint, re-pairing worked fine. this time I did it with the latest JAR you provided and paired it locally on the machines browser.
openhab log confirms successfull Connection (like last time)
2016-12-27 17:53:05.164 [INFO ] [.service.AbstractActiveService] - Google Calender Event-Downloader has been started
I already scheduled an Event and it worked fine (like last time).
last time, failure showed up after a few hours. Iāll watch it and report back if failure Comes up again after a few hours.
since i restarted the process again with your latest jar, everything works fine. issue did not came back so far. even after a restart of openhab, everything continues to work fine. seems like problem is fixed.
quick last question. how do I know thereās a new JAR binding since itās not included in the official add-on download ? is there a URL I can check if thereās an updated binding ?
thanks again for your help
Juerg
Hi John,
it happened once again, but this time after a few days. gcal binding just gave up in the middle of the night.
2016-12-30 23:37:13.781 [ERROR] [.service.AbstractActiveService] - Error while executing background thread Google Calender Event-Downloader
at org.openhab.io.gcal.internal.GCalEventDownloader.processEntries(GCalEventDownloader.java:276) ~[na:na]
at org.openhab.io.gcal.internal.GCalEventDownloader.execute(GCalEventDownloader.java:140) ~[na:na]
sure. can you please remind me how to run this in debug mode / how to turn it on ? sorry for the basic question but iām not really used to this.
thanks
I will try to make use of that log, but it looks like the lines were truncated (bad for knowing more about the entries but good for not printing complete tokens should anyone want to misuse them!)
I will let you know if I need more, and thanks for providing it.
