Whoops, thanks, fixed!
I know, it’s frustrating… it’s white (the default) before the JS library in charge of hiding the header is loaded and takes over. No solution yet but will keep looking when I get the time.
Fair.
That’s me grabbing a quick screenshot of the demo rules a long time ago and never updating it. If someone’s got a better image to submit, PRs are welcome, the file is here: https://github.com/openhab/website/blob/master/.vuepress/public/vscode.png
Good point, for now there’s a banner but eventually docs.openhab.org could redirect automatically to the new URL, yes.
Oh, and new since yesterday: @chris has done a tremendous job generating user-friendly documentation from the device database for all and every of the 745 things supported by the Z-Wave binding - with channel descriptions, inclusion information etc. -, which the website is now able to display. You can also search the model number of your device or a generic term (e.g. “smoke”, “alarm”, “door” etc.) in the big search box at https://www.openhab.org/addons/ to check whether it’s supported or not, clicking on the device name will take you directly to the thing’s description page.
there you go:
I tried to keep it close to how Alexa usage was described, to have it somehow symetric for the users.
I think the new website should point to that usage guide and not to the technical instructions anymore.
BR Mehmet
Today I found some interesting code for the GA integration that respects the DNT settings and uses GA without cookies (everything is stored in the session storage):
<script>
var dnt = (navigator.doNotTrack || window.doNotTrack || navigator.msDoNotTrack);
var doNotTrack = (dnt == "1" || dnt == "yes");
if (!doNotTrack) {
window.ga=window.ga||function(){(ga.q=ga.q||[]).push(arguments)};ga.l=+new Date;
if (window.sessionStorage) {
var GA_SESSION_STORAGE_KEY = 'ga:clientId';
ga('create', 'UA-xxxx-x', {
'storage': 'none',
'clientId': sessionStorage.getItem(GA_SESSION_STORAGE_KEY)
ga(function(tracker) {
sessionStorage.setItem(GA_SESSION_STORAGE_KEY, tracker.get('clientId'));
ga('set', 'anonymizeIp', true);
ga('send', 'pageview');
</script>
<script async="" src="//www.google-analytics.com/analytics.js"></script>
This code is generated by Hugo for GA integration. I will test it now on my own website.
@ysc I think I found another todo
If you put a link to the new docs in the community forum, it does not yet show a nice card, but only the plain text link.
Not so easy, it would require the site to support oEmbed or writing a plugin for https://github.com/discourse/onebox…
Interesting. Currently it simply uses VuePress’ built-in support (with the anonymizeIp option on top), using custom code instead is probably possible though - or proposing the option in a PR to VuePress itself.
OK, I thought that we have full control about the GA integration. The code seems to work really good. I have tested it today and it really works without any cookies.
Done & done!
Legacy bindings also show a warning banner on the page:
They don’t appear in the side navigation, only in the search page when “show legacy add-ons” is checked:
You can also search for them: they will have a “(1.x)” suffix.
calling all designers out there: Plz come up with a cool Logo for the Design Patterns of @rlkoshak so they pop up nicely on https://www.openhab.org/about/showcase.html
The current images are not so… great lol
I’m just playing around as I go through and update the DPs to reflect the changes added in 2.3. Now that we have https://www.openhab.org/about/showcase.html I wanted the DPs that show up there to at least have something to distinguish them.
Though the “123” is specific to that DP. I call that approach the 1-2-3 Rule Structure. The second one is probably too obtuse. The DP is about encoding data so there is a Morse Code paddle.
I thought I had removed the image from about DPs posting though.
I am rather happy with the Time of Day image though.
Of course I’m open to any improvements. Graphic Designer I am not.
Out of curiosity, what is the criteria for how to articles showing in the showcase? Is it based on the some tag, like the HabPanel widgets?
I think it is based on number of likes.
I see that now - the articles I have >10 likes on show up, while the remainder doesn’t. Thanks!
It’s actually the same list as
https://community.openhab.org/c/tutorials-examples/l/top/all
(top topics in Tutorials & Examples of all time)
Not sure about the order though.
I see the new images for the design pattern topics have messed up the showcase list a little - it overflows to 4 columns. That’s because I cheated a little will fix later.
By the way, in case you haven’t seen it:
I finallly finished it, for those interested:
Sorry about that. I was just trying to fit in with all the cool images the other posts had. I can remove them.
No worries and no need, I fixed it already.
One question on new website. Can you fix the links in google?
For example if I google “tradfri binding openhab”
It shows the link to the old site?
Congratulations for the new website.
I really do like that the old documentation automatically notifies with a link to the new documentation page.
In case of the icons (https://docs.openhab.org/addons/iconsets/classic/readme.html) the link that points to the new documentation points to 404: https://www.openhab.org/addons/iconsets/classic/
I think the correct link should be https://www.openhab.org/docs/configuration/iconsets/classic/
The old docs have a better PageRank so they’re still presented first. This will get better over time as new pages are linked from elsewhere, but it’s probably going to stay that way for a while and until they are completely removed.
If you only want results from the new website add site:www.openhab.org
to the query
For instance www.google.com/search?q=tradfri+site:www.openhab.org
