I wanted to see if anyone has any advice for an issue I’m seeing. When I toggle the GE normal switch on a 3-way circuit everything works fine and openhab shows the proper state. If on the other hand I press the add a switch (3-way switch) openhab does not see a state change and still shows the original state… ideas? Workarounds other than not using that switch?!
