I have the device https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/740, and I’ve linked the alarm_burglar channel on endpoint two to an item:
Switch GuestBathLights_Contact "Guest Bathroom Lights Occupancy" { channel="zwave:device:512:node43:alarm_burglar2" }
When I turn on debug logging, I see that the device is sending a notification when I trigger it:
2019-03-06 17:12:54.697 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 13 00 04 00 2B 0D 60 0D 02 01 71 05 00 00 00 FF 07 08 00 24
2019-03-06 17:12:54.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=43, callback=0, payload=00 2B 0D 60 0D 02 01 71 05 00 00 00 FF 07 08 00
2019-03-06 17:12:54.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=43, callback=0, payload=00 2B 0D 60 0D 02 01 71 05 00 00 00 FF 07 08 00
2019-03-06 17:12:54.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-03-06 17:12:54.698 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Application Command Request (ALIVE:DONE)
2019-03-06 17:12:54.698 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: resetResendCount initComplete=true isDead=false
2019-03-06 17:12:54.698 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2019-03-06 17:12:54.698 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: Incoming command class COMMAND_CLASS_ALARM, endpoint 2
2019-03-06 17:12:54.698 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: SECURITY not supported
2019-03-06 17:12:54.698 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 43: Received COMMAND_CLASS_ALARM V4 NOTIFICATION_REPORT
2019-03-06 17:12:54.698 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 43: NOTIFICATION report - 0 = 0, event=8, status=255, plen=0
2019-03-06 17:12:54.699 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 43: Alarm Type = BURGLAR (0)
2019-03-06 17:12:54.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 43: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2019-03-06 17:12:54.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 43: Got a value event from Z-Wave network, endpoint=2, command class=COMMAND_CLASS_ALARM, value=255
2019-03-06 17:12:54.699 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 43: Alarm converter processing NOTIFICATION
2019-03-06 17:12:54.699 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - NODE 43: Alarm converter NOTIFICATION event is 8, type OnOffType
2019-03-06 17:12:54.699 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Commands processed 1.
2019-03-06 17:12:54.699 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@f6bf976.
2019-03-06 17:12:54.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-03-06 17:12:54.700 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
But it doesn’t update my item. Shortly after I get the update on the dimmer part itself, and that works fine:
2019-03-06 17:12:54.721 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 2B 07 60 0D 01 01 26 03 63 F1
2019-03-06 17:12:54.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=43, callback=0, payload=00 2B 07 60 0D 01 01 26 03 63
2019-03-06 17:12:54.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=43, callback=0, payload=00 2B 07 60 0D 01 01 26 03 63
2019-03-06 17:12:54.721 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-03-06 17:12:54.722 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Application Command Request (ALIVE:DONE)
2019-03-06 17:12:54.722 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: resetResendCount initComplete=true isDead=false
2019-03-06 17:12:54.722 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2019-03-06 17:12:54.722 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2019-03-06 17:12:54.722 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 43: SECURITY not supported
2019-03-06 17:12:54.722 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 43: Received COMMAND_CLASS_SWITCH_MULTILEVEL V2 SWITCH_MULTILEVEL_REPORT
2019-03-06 17:12:54.722 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 43: Switch Multi Level report, value = 99
2019-03-06 17:12:54.722 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 43: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2019-03-06 17:12:54.723 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 43: Got a value event from Z-Wave network, endpoint=1, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=99
2019-03-06 17:12:54.723 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 43: Updating channel state zwave:device:512:node43:switch_dimmer1 to 100 [PercentType]
2019-03-06 17:12:54.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Commands processed 1.
2019-03-06 17:12:54.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 43: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@459188bd.
2019-03-06 17:12:54.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-03-06 17:12:54.723 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
@chris Is this another case similar to [SOLVED] GE/Jasco ZW6302 (34193) zwave motion sensor events ignored where the database just needs a slight tweak to use alarm_motion rather than alarm_burglar?
