GE Smart Switch not throwing double tap scene event
You need to:
  1. manually install the zwave binding. (This script should do the work but I haven’t personally tried it https://github.com/openhab-5iver/openHAB-utils/releases )
  2. Stop openhab
  3. update the jar file with the new XML files (I used these instructions as a base. Modify a zwave binding jar to add/change a zwave device while waiting for a build )
  4. Start openhab
@chris Any chance I can get zwave database write access? WRXIzumi on the database site.
