in PaperUI I have an switch-item called “Reset_Consumables” with is defined as a switch with different kind of values: “Select Consumables”, “Reset Filter” and so on.
Now I want to transform this item as a sitemap-item:
Selection item=Reset_Consumables
but I don’t know the correct mappings-array.
I tried out with different values like mappings=[select_consumables=“a”, reset_filter=“b”…] and mappings=[consumables=“a”, filter=“b”, …] or [1=“a”, 2=“b”…]
but nothing works (this means: the reset doesn’t take place in sitemaps, but in paperui the selected value resets the choosen consumable).
Is there a strange-forward-way to transform paperUI-Mappings in mappings for items in basicUI-sitemaps?
Or a way to get the information how I can get the correct values for the sitemap-mapping?
Greetings!
