After following the steps for Developing a Binding in the openHAB documentation it took some time to get the generated skeleton built and succesfully tested. The following issues exist:
The copyright information of the generated java files does not match the expectations
of the code analysis,
the file NOTICE is missing
the test in xxxOSGiTest.java fails
the test in xxxHandlerTest.java uses method handler.initialize() which is marked deprecated in BaseThingHandler.java.
If someone could point me to the corresponding repository, I would like to contribute and issue a PR to correct this.
Thanks for taking care of those issues. Both scripts (ESH and OH2) are based on the same archetype skeleton which is located in the ESH repo - you already found the right place.
I recently committed an update for the documentation which contains some notes about the current differences (e.g. license and copyright information) for the two environments. Have a look here.
Thanks, it would be cool to merge your PR - did you see the comments wrt signing the commits? Would be great if you could do so. Let me know, if you have any questions about that!
