Generator hours counter
Does this work?
import static java.lang.Math.round
round(totalMsec/1000/60/60)
Crap, right, static methods need to be referenced using ::
So it should probably be
import java.lang.Math
val long hours = Math::round(totalMsec/1000/60/60)
I simply add that at the top of the .rules right? As soon as I do that it looks like the rule stops running. I no longer see the:
2015-10-21 10:09:04.339 [INFO ] [openhab.model.script.GenUptime] - Generator is not running
2015-10-21 10:09:05.000 [INFO ] [openhab.model.script.GenUptime] - Generator is not running
If I edit the rule and take out the import line I start seeing the not running lines in logs.
Sorry; it must be a case where Xtend and the openHAB rule language differ. Rich’s approach should work.
It does!!! Odd sometimes how openhab does not throw errors.
Does this mean the rule overall works now?
Sure does! I am trying to get it to give me fractions of hours. I know that round() only rounds to whole numbers so I tried:
    val long hours = (Math::round(totalMSec/100/60/60)) /10
Thinking that /100 rather then /1000 would give me a larger number but when I / 10 I still get a whole number.
Dealing with decimal points on computers is surprisingly challenging. Most people don’t realize that computers are really horrible at doing decimal math.
This little trick will work most of the time:
val long temp = Math::round((totalMSec/100/60/60) * 10) // calculate the hours and move the decimal place before rounding to preserve the tenths place
val double hours = temp / 10.0 // move the decimal place back to get the tenth's place, change the type to double  so we don't lose the decimal place
Because computers are really bad at representing floating point numbers, there may be cases where you end up with something like “5.1000000000000005” instead of “5.1”. I don’t think it will occur frequently, but if it does the “fix” will be a little more tricky and involved.
However, it is better to not round at all and use the formatting on the labeltext for the Item to only show one decimal place.
Item GeneratorRuntimeHours "Generator Runtime Hours [%.f1]" ...
In the rule change the type of hours to a double and don’t round at all.
val double hours = totalMSec/100/60/60
If you want two decimal places just change the stuff in brackets to [%f.2].
I tried :
    val double hours = totalMSec/1000/60/60
Tho I still got whole numbers, I am using the correct display:
Number		GeneratorRuntimeHours		"Generator Runtime [%.1f Hours]"	   <generator>
Its an old trick that I didn’t think was still necessary. Try:
val double hours = totalMSec/1000.0/60.0/60.0
Perfect!
Awesome thread guys. Bookmarked for the day I have an automatic start/stop generator!
I have done remote site generator monitoring and something that does tend to come up (in many areas in fact) is drift between the generators hour meter and the calculated values from the controller. If you are storing/persisting the total run hours, and you have a means of updating that counter, you can periodically do a manual meter read and update the system with the “correct” value from the generator.
Another though, which is much simpler, but requires more storage, is just to store the current generator state every minute (or 5,10,15 minutes) as well as the run hours. This way it is really easy to just sum the run time between a start and end point in order to see how long the generator ran during that period.
There is always more than one way to solve a problem. I’m glad you posted this alternative method.
I think the big differences between the two approaches is when you do the math to come up with the total hours. Our approach does the math as values come up. Your approach does the math only when you look. Both have their place.
Rich
I just do that in the .rules:
val double hours = totalMSec/1000.0/60.0/60.0 + 100.3
Couldn’t agree more… I am tracking my energy use, and using both approaches. Must say that having the meter indexes at the begining of the month and throughout has bailed me out a number of times when there has been lost data… as you can still tell how much was used during the outage.
Hi @sipvoip, could you post the final code for the counter?
import org.openhab.model.script.actions.*
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
var org.joda.time.DateTime whenStarted = null
var Timer generator_status_timer = null
var Timer generator_load_timer = null
var Lock lock = new ReentrantLock()
rule "Generator Started"
	Item Generator_Auto received command ON or
	Item Generator_Override received command ON
	logInfo("Testing", "Generator Started - Locking")
	lock.lock()
	try {
		sendCommand(Generator_Start, ON)
		Thread::sleep(45000) // Let Generator spool up
			if (Generator_Status.state == CLOSED) {
				sendCommand(Generator_Failed, OFF)
				sendCommand(Generator_Cooling, OFF)
				whenStarted = now // Start Clock
				generator_load_timer = createTimer(now.plusSeconds(15))
						sendMail("8323303810@mms.att.net", "Generator", "Generator Started, load at " + Buy_Total_Watts.state + " watts")
			} else {
				sendCommand(Generator_Failed, ON)
				sendCommand(Generator_Override, OFF)
				sendMail("8323303810@mms.att.net", "Generator", "Generator Failed to Start!!")
	finally {
		lock.unlock()
		logInfo("Testing", "Generator Started - Unlocked")
rule "Generator Stopped"
	Item Generator_Auto received command OFF or
	Item Generator_Override received command OFF
	lock.lock()
	try {
		sendCommand(Generator_Start, OFF)
		postUpdate(Generator_Auto, OFF)
		postUpdate(Generator_Override, OFF)
		postUpdate(Generator_Cooling, ON)
		Thread::sleep(90000) // Let Generator cool down
		postUpdate(Generator_Cooling, OFF)
    		whenStarted = null
	finally {
		lock.unlock()
rule "Check Generator and Increment Runtimes"
    	Time cron "0 0/1 * * * ?"
	logInfo("Testing", "Check Generator and Increment Runtimes - Locking")
	lock.lock()
	try {
		// Check if Generator is running already
		if (Generator_Status.state == CLOSED && whenStarted == null) whenStarted = now
		if (Generator_Status.state == CLOSED && Generator_Auto.state == OFF && Generator_Override.state == OFF && Generator_Cooling.state == OFF) {
			postUpdate(Generator_Override, ON)
			whenStarted = now
			sendMail("8323303810@mms.att.net", "Generator", "Generator Started Manually")
		// Check if Generator failed
		if (Generator_Status.state == OPEN && Generator_Auto.state == ON) {
			sendCommand(Generator_Auto, OFF)
			sendMail("8323303810@mms.att.net", "Generator", "Generator Failed!!")
		// Increment Runtimes
		if(Generator_Status.state == CLOSED) {
			val long nowMSec = now.millis
			val long wsMSec = whenStarted.millis
			whenStarted = now
        		val long timeSinceLastUpdate = nowMSec - wsMSec
			val long oldVal = (Generator_Runtime_MSec.state as Number).longValue
			val long totalMSec = oldVal + timeSinceLastUpdate // calculate total runtime
        		Generator_Runtime_MSec.postUpdate(totalMSec) // post the full runtime
        		Generator_Runtime_Hours.postUpdate(hours)
			// Caculate runtime for today
			val long todayOldVal = if(Today_Generator_Runtime_MSec.state == Uninitialized) 0 else (Today_Generator_Runtime_MSec.state as Number).longValue
			val long todayTotalMSec = todayOldVal + timeSinceLastUpdate // calculate total runtime
			Today_Generator_Runtime_MSec.postUpdate(todayTotalMSec) // post the full runtime
			val double todayHours = todayTotalMSec/1000.0/60.0/60.0
        		Today_Generator_Runtime_Hours.postUpdate(todayHours)
	finally {
		lock.unlock()
		logInfo("Testing", "Check Generator and Increment Runtimes - Unlocked")
rule "Today Generator Runtime Reset"
	Time cron "50 59 23 * * ?"
	Today_Generator_Runtime_MSec.postUpdate(0)
Very nice thread ! What is your hardware? I mean what kind is your generator used? How to connect it to OpenHab? @sipvoip
Generac 20kw and set it up for 2 wire start and then control it via a relay off a pokeys 57 board.
how can you connect them to openhab? what was the setup and configuration?
