Generator hours counter
Couldn’t agree more… I am tracking my energy use, and using both approaches. Must say that having the meter indexes at the begining of the month and throughout has bailed me out a number of times when there has been lost data… as you can still tell how much was used during the outage.
Hi @sipvoip, could you post the final code for the counter?
import java.lang.Math
import org.openhab.model.script.actions.*
import java.util.concurrent.locks.Lock
import java.util.concurrent.locks.ReentrantLock
var org.joda.time.DateTime whenStarted = null
var Timer generator_status_timer = null
var Timer generator_load_timer = null
var Lock lock = new ReentrantLock()
rule "Generator Started"
	Item Generator_Auto received command ON or
	Item Generator_Override received command ON
	logInfo("Testing", "Generator Started - Locking")
	lock.lock()
	try {
		sendCommand(Generator_Start, ON)
		Thread::sleep(45000) // Let Generator spool up
			if (Generator_Status.state == CLOSED) {
				sendCommand(Generator_Failed, OFF)
				sendCommand(Generator_Cooling, OFF)
				whenStarted = now // Start Clock
				generator_load_timer = createTimer(now.plusSeconds(15))
						sendMail("8323303810@mms.att.net", "Generator", "Generator Started, load at " + Buy_Total_Watts.state + " watts")
			} else {
				sendCommand(Generator_Failed, ON)
				sendCommand(Generator_Override, OFF)
				sendMail("8323303810@mms.att.net", "Generator", "Generator Failed to Start!!")
	finally {
		lock.unlock()
		logInfo("Testing", "Generator Started - Unlocked")
rule "Generator Stopped"
	Item Generator_Auto received command OFF or
	Item Generator_Override received command OFF
	lock.lock()
	try {
		sendCommand(Generator_Start, OFF)
		postUpdate(Generator_Auto, OFF)
		postUpdate(Generator_Override, OFF)
		postUpdate(Generator_Cooling, ON)
		Thread::sleep(90000) // Let Generator cool down
		postUpdate(Generator_Cooling, OFF)
    		whenStarted = null
	finally {
		lock.unlock()
rule "Check Generator and Increment Runtimes"
    	Time cron "0 0/1 * * * ?"
	logInfo("Testing", "Check Generator and Increment Runtimes - Locking")
	lock.lock()
	try {
		// Check if Generator is running already
		if (Generator_Status.state == CLOSED && whenStarted == null) whenStarted = now
		if (Generator_Status.state == CLOSED && Generator_Auto.state == OFF && Generator_Override.state == OFF && Generator_Cooling.state == OFF) {
			postUpdate(Generator_Override, ON)
			whenStarted = now
			sendMail("8323303810@mms.att.net", "Generator", "Generator Started Manually")
		// Check if Generator failed
		if (Generator_Status.state == OPEN && Generator_Auto.state == ON) {
			sendCommand(Generator_Auto, OFF)
			sendMail("8323303810@mms.att.net", "Generator", "Generator Failed!!")
		// Increment Runtimes
		if(Generator_Status.state == CLOSED) {
			val long nowMSec = now.millis
			val long wsMSec = whenStarted.millis
			whenStarted = now
        		val long timeSinceLastUpdate = nowMSec - wsMSec
			val long oldVal = (Generator_Runtime_MSec.state as Number).longValue
			val long totalMSec = oldVal + timeSinceLastUpdate // calculate total runtime
        		Generator_Runtime_MSec.postUpdate(totalMSec) // post the full runtime
			val double hours = totalMSec/1000.0/60.0/60.0
        		Generator_Runtime_Hours.postUpdate(hours)
			// Caculate runtime for today
			val long todayOldVal = if(Today_Generator_Runtime_MSec.state == Uninitialized) 0 else (Today_Generator_Runtime_MSec.state as Number).longValue
			val long todayTotalMSec = todayOldVal + timeSinceLastUpdate // calculate total runtime
			Today_Generator_Runtime_MSec.postUpdate(todayTotalMSec) // post the full runtime
			val double todayHours = todayTotalMSec/1000.0/60.0/60.0
        		Today_Generator_Runtime_Hours.postUpdate(todayHours)
	finally {
		lock.unlock()
		logInfo("Testing", "Check Generator and Increment Runtimes - Unlocked")
rule "Today Generator Runtime Reset"
	Time cron "50 59 23 * * ?"
	Today_Generator_Runtime_MSec.postUpdate(0)
Very nice thread ! What is your hardware? I mean what kind is your generator used? How to connect it to OpenHab? @sipvoip
Generac 20kw and set it up for 2 wire start and then control it via a relay off a pokeys 57 board.
how can you connect them to openhab? what was the setup and configuration?
I’m looking at porting your rule to control a 30HP industrial compressor
of all these variable I’d like help understanding what one are connected to physical switches and sensors and what are virtual switches and counters as well as all the items that need to be in the items file
generator_status_timer				//Declared but never used
generator_load_timer					Rule_Number				//Delay timer for load reading
Buy_Total_Watts.state					Item_Number_Physical	//Power reading from other device
Generator_Auto			"ON/OFF"
Generator_Override		"ON/OFF"
Generator_Start			"ON/OFF"
Generator_Status		"OPENED/CLOSED"	Item_Contact_Physical
Generator_Failed		"ON/OFF"		Item_Switch_Virtual		//genset Failed Indicator
Generator_Cooling		"ON/OFF"		Item_Switch_Virtual		//Delayed mode indicator to allow genset to cool before restart
whenStarted				"null/TIME"
Generator_Runtime_MSec					Item_Number_Virtual		// used to store intermediate values which get rounded
Generator_Runtime_Hours	"%.1f Hours"	Item_Number_Virtual		// used on sitemap
todayTotalMSec
todayOldVal
timeSinceLastUpdate
todayHours
Thanks,
This is very similar to what I’d like to achieve.
I need to track daily heating hours for three rooms.
It gets complicated because of difficulties using arrays in rules.
Is there any updated script as this one seems to use old openhab..?
This declaration doesn’t work for me:
Thanks!
There are no difficulties using arrays in Blockly, JS Scripting, Nashorn JS, Groovy, or jRuby. It’s only Rules DSL that makes it so you have to use a List instead of an array.
Given you’ve reopened a thread that is over seven years old, yes it is in fact using old openHAB.
I recommend opening a new thread but first give a try at implementing this using Blockly. Given all the new features added to OH in the past seven years, I believe the overall approach can be much simpler. 1. Trigger when the heater changes
2. If it changed to ON, capture the current time and put it into the cache.
3. If it changed to OFF, capture the difference between the time captured in 2 and now and add that to your total runtime Item
If you want to have a constant count up while the heater is running:
  1. Trigger the rule every second (or what ever time period you care about, once per second is as fast as it gets though)
  2. Set a condition to no run the actions if the heating is OFF
  3. Increment the HeatingOnTime Item by the cron period.
The second approach is like two lines of code in the UI.
I might have get you covered using DSL rules:
This one doesn’t need a whenStarted variable/item as it takes the time from persistence service. It also supports constant count up (granularity configurable). Hope it is of some help.
1. Items
Switch Generator_Running "Generator Running" <generator>
Number Generator_Runtime "Generator Runtime [%.2f h]" <clock>
2. Complete JavaScript Rule with rule {}
var logger = Java.type(“org.slf4j.LoggerFactory”).getLogger(“org.openhab.model.script.Generator”);
rule({
name: "Generator Runtime Tracker",
description: "Tracks total generator runtime in hours",
tags: \["generator", "runtime"\],
triggers: \[
    // Time cron trigger: every minute
    triggers.TimeCronTrigger("0 \* \* \* \* ?")
execute: function(event) {
    var Generator_Running = items.getItem("Generator_Running");
    var Generator_Runtime = items.getItem("Generator_Runtime");
    if (Generator_Running.state == "ON") {
        var currentRuntime = parseFloat(Generator_Runtime.state.toString());
        var newRuntime = currentRuntime + (1.0 / 60); // 1 minute = 1/60 hours
        Generator_Runtime.postUpdate(newRuntime);
        logger.info("Generator runtime updated: " + newRuntime + " h");
3. Persistence (MapDB recommended)
Items {
Generator_Runtime : strategy = everyChange, restoreOnStartup
Or with an esphome device
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: “YOUR_WIFI_SSID”
password: “YOUR_WIFI_PASSWORD”
logger:
ota:
mqtt:
broker: “YOUR_MQTT_BROKER_IP”
username: “MQTT_USER”
password: “MQTT_PASSWORD”
topic_prefix: “home/generator”
# Generator running sensor
binary_sensor:
  • platform: gpio
    pin:
    number: GPIO14
    mode: INPUT_PULLUP
    device_class: power
    filters:
    • delayed_on: 100ms
    • delayed_off: 100ms
# Calculate runtime in hours with persistence
sensor:
  • platform: integration
    sensor: generator_running
    unit_of_measurement: “h”
    time_unit: “h”
    accuracy_decimals: 2
    restore_value: yes # ← Restore from flash (EEPROM)
    filters:
    • multiply: 1.0
    state_topic: “home/generator/runtime”
# Optional: Status LED
output:
  • platform: gpio
    pin: GPIO2
Edit: on my mobile I can’t do a complete syntax highlighting even not if I use ``` it’s only line by line there for I skip it :frowning:
I suffer from bad code highlighting since the forum software was updated.
I will create an issue …
I overlooked the new (?) option to switch between “Rich text editor” and “Markdown editor”.
grafik
With “Markdown editor” the old behaviour is back and also the preview is working again.
