I have a gas meter which reports the cumulative meter value every minute. I now would like to create a new item which logs the difference between the current and previous value.
Something like this:
rule "Gas consumption"
Item GasmeterLastValue changed
var Number currentStateValue = GasmeterLastValue.state
var Number previousStateValue = GasmeterLastValue.previousState.state
var Number diff = currentStateValue - previousStateValue
GasmeterDiscreteValue.postUpdate(diff)
But this is apparently not the correct syntax. Could I get some help with this?
