I currently have multiple echo dots in the house, and some of my openhab items are exposed using the cloud connector.
I was wondering if its possible to get the device name of the echo dot that is requesting the command sent over to openhab so that i can use that information in a rule? Like create a rule that will only continue if the echo dot is echo dot 1 and not echo dot 2.
thanks in advance.
