Your command will download the file into the directory /LightEASY/conf/html/CoverSpoty.png
Are you sure that is the full path?
Then you can point an image sitemap item to the path or into habpanel
Download the file into /etc/openhab2/html instead
That directory is accessible by the UIs
‘wget -o /LightEASY/conf/html/CoverSpoty.png https://i.scdn.co/image/a147c4341a66d216ee61b6b108d9b8fdc71dd8c8’
java.io.IOException: Cannot run program “wget”: CreateProcess error=2, El sistema no puede encontrar el archivo especificado
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:620) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:450) ~[?:?]
at java.lang.Runtime.exec(Runtime.java:347) ~[?:?]
at org.eclipse.smarthome.io.net.exec.ExecUtil.executeCommandLine(ExecUtil.java:63) ~[?:?]
at org.eclipse.smarthome.model.script.actions.Exec.executeCommandLine(Exec.java:43) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:345) ~[?:?]
