I’m trying to get a list of items depending on the state of another Item. But currently I only get errors “Type cannot be derived” and I dont find my mistake.
Here a short snippet what I want to do in Openhab Rule:
var rollershutter_down
if (setting_absent.state == ON){
rollershutter_down = gRollershutter.allMembers
else{
rollershutter_down = gRollershutterDown.allMembers
Currently I’m not sure if its possible to filter items like that?
Perhaps someone has a hint for me? 0:-)
Thanky you
So you have two Groups, one named gRollershutter and the other named gRollershutterDown. If setting_absent.state is ON determines which of the members you get.
There is nothing wrong with this code as written, assuming that setting_absent is a Switch Item and gRollershutter and gRollershutterDown are both Group Items.
hmm, I’m not quite sure. But the following is logged:
20:46:19.263 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'devel.rules', using it anyway:
The value of the local variable rollershutter_down is not used
And I don’t know whats wrong with this code
Meanwhile i found another way to get the same result with:
val rollershutter_down = gRollershutter.allMembers.filter[item |
setting_absent.state == ON || setting_absent.state != ON && item.getGroupNames.contains("gRollershutterDown")
The rule validator is smart to spot if you create a variable, even set it, but then don’t do anything useful with it later. The snippet you showed us does not “use” that variable.
I know, the error message “The value of the local variable rollershutter_down is not used” is not my problem. Even if I use the variable, e.g. print to log or loop through, it’s empty and I get the other error messages “Validation issues found in configuration model 'devel.rules', using it anyway: Type cannot be derived”
rule "devel"
Item date changed
else{
logInfo("Notification", rollershutter_down)
results in
13:05:53.756 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'devel.rules'
13:05:53.813 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'devel.rules', using it anyway:
rollershutter_down isn’t a string, and I don’t suppose the validator can guess what kind of object it might be at this point, so it cannot work out if can be coerced to a string
Try logInfo("Notification", "My variable {}", rollershutter_down)
Mind you -
having an Item named date looks like a recipe for keyword confusion.
