Hi all
I just bind a motion detection device of NEO Coolcam.
The issue is that I am receiving information from the device of the Luminance Sensor and the Temperature Sensor but I do not receive any motion detection events or battery level.
The sensor is flashing when there is motion near it.
No log for the detection.
I added a rule for the detection that is not triggered either.
What can I do?
Maybe something with the definition of the sensor?
Can you check in Paper UI - Configuration - Items
if the Item is shown
Maybe you must delete the motion in Paper UI Configuration - Things
From the channels because you can declare an Item just once.
Ok that means it is declared on just one place.
It looks all OK. may-be you should try to delete the device in Configuration things (with the garbage bin)
and add it again
