HI, my first attempt with openhab and z wave and I am a bit stuck . Hoping some kind person can point me in the right direction.
I have the Z stick gen 5 from Aeotec and one other z wave device, a fibaro dimmer 2. I seem to have successfully wired the F dimmer 2 at the back of a switch to control my bathroom LED spots. Upon turning power on, the lights went on dimming to max and then down. Then I unplugged the z stick and pressed the button and it start blink blue. Then I click the switch three times, and after a while the z stick flashed blue for a short while, is this pairing OK?
The, back on my laptop I tried to go to http://127.0.0.1:8080/openhab.app?sitemap=demo
This page seems to show stuff according to a sitemap example file I used (not according my setup):
sitemap demo label=“Main Menu” {
Frame label=“Date” {
Text item=Date
Frame label=“Demo” {
Text label=“Group Demo” icon=“1stfloor” {
Switch item=Lights mappings=[OFF=“All Off”]
Group item=Heating
Text item=Temperature valuecolor=[>25=“orange”,>15=“green”,<=15=“blue”]
Text label=“Multimedia” icon=“video” {
Selection item=Radio_Station mappings=[0=off, 1=HR3, 2=SWR3, 3=FFH, 4=Charivari]
Slider item=Volume
In Items folder I have only fib.items with the contetns shown under. Now, from the z wave log, it seems that 2 nodes are found, so I suppose that is the USB stick and the lights. But it seems to me that openhab does not associate the Fibaro with the stuff in fib.items, or I need to change the sitemap to include the “Foo” unit? Please help!
Switch foo “Foo” { zwave=“42:command=SWITCH_MULTILEVEL” }
Dimmer foo_dim “Foo [%d %%]” { zwave=“42:command=SWITCH_MULTILEVEL” }
Number foo_power “Foo - current power consumption [%.2f W]” { zwave=“42:command=METER,meter_scale=E_W,refresh_interval=300” }
Number foo_energy “Foo - total energy use [%.2f KWh]” { zwave=“42:command=METER,meter_scale=E_KWh,refresh_interval=300” }
The z wave log is now 180kB. Heres the last few lines, its too much to include all I suppose.
2016-10-16 16:14:42.564 [DEBUG] [WaveController$ZWaveSendThread:1268]- NODE 2: Sending REQUEST Message = 01 08 00 13 02 01 00 25 19 DB
2016-10-16 16:14:42.573 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 04 01 13 01 E8
2016-10-16 16:14:42.574 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-10-16 16:14:42.574 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-10-16 16:14:42.575 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 04 01 13 01 E8
2016-10-16 16:14:42.576 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 04 01 13 01 E8
2016-10-16 16:14:42.577 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Response (0x01), payload = 01
2016-10-16 16:14:42.577 [DEBUG] [b.z.i.p.s.SendDataMessageClass:38 ]- NODE 2: Sent Data successfully placed on stack.
2016-10-16 16:14:42.594 [DEBUG] [eController$ZWaveReceiveThread:1481]- Receive Message = 01 07 00 13 19 00 00 03 F1
2016-10-16 16:14:42.595 [DEBUG] [eController$ZWaveReceiveThread:1405]- Receive queue ADD: Length=1
2016-10-16 16:14:42.595 [DEBUG] [b.z.i.protocol.ZWaveController:1163]- Receive queue TAKE: Length=0
2016-10-16 16:14:42.596 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 09 00 13 19 00 00 03 00 00 FF
2016-10-16 16:14:42.597 [DEBUG] [b.z.i.protocol.ZWaveController:1164]- Process Message = 01 09 00 13 19 00 00 03 00 00 FF
2016-10-16 16:14:42.597 [DEBUG] [b.z.i.protocol.ZWaveController:192 ]- Message: class = SendData (0x13), type = Request (0x00), payload = 19 00 00 03
2016-10-16 16:14:42.598 [DEBUG] [b.z.i.p.s.SendDataMessageClass:74 ]- NODE 2: SendData Request. CallBack ID = 25, Status = Transmission complete and ACK received(0)
2016-10-16 16:14:42.599 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:63 ]- Sent message Message: class = SendData (0x13), type = Request (0x00), payload = 02 01 00
2016-10-16 16:14:42.599 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:64 ]- Recv message Message: class = SendData (0x13), type = Request (0x00), payload = 19 00 00 03
2016-10-16 16:14:42.600 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:65 ]- Checking transaction complete: class=SendData, expected=SendData, cancelled=false
2016-10-16 16:14:42.600 [DEBUG] [.z.i.p.s.ZWaveCommandProcessor:68 ]- transaction complete!
2016-10-16 16:14:42.600 [DEBUG] [b.z.i.protocol.ZWaveController:635 ]- Notifying event listeners: ZWaveTransactionCompletedEvent
2016-10-16 16:14:42.601 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-10-16 16:14:42.601 [DEBUG] [WaveController$ZWaveSendThread:1327]- NODE 2: Response processed after 36ms/106ms.
