after one 25. Build i now have always one error in the log:
[me.storage.json.internal.JsonStorage] - Couldn’t deserialize value ‘org.eclipse.smarthome.storage.json.internal.StorageEntry@e6b2e9’. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels
How could i identify the Storage-Entry wich causes the error ?.
Try running a diff between the files in /var/lib/openhab2/jsondb and their backups in /var/lib/openhab2/jsondb/backups and see if there are any differences between them which might point to a problem. It will at least tell you what changed between when it worked and when it stopped working.
The openHAB Core caused those problems for a few builds after the json library had been updated. It should work again, but not all tests in core have been re-enabled yet to detect those problems automatically.
All values that have been written with such a problematic core version (OH snapshots only!) are corrupt.
It looks like one of the Things is effected in this case (because of “$channels”).
