Getting my LG TV Connected & Switch & Info Question
Using openhab 2.5 m2. On a raspberryPi 3b.
I have my LG TV Connected to openhab. Works fine. Gives the info and functions I need. For input source there is a string item that displays the source com.webos.app.livetv, com.webos.app.hdmi1 etc.
I created a few lines in my MAP file
com.webos.app.hdmi2=KODI
com.webos.app.hdmi1=PS4
But the log keeps raising an error claiming that it can’t find an entry in my map file. Its weird. the map file works fine with other items. I tried putting it between quotes but that did not help.
Now when I want to use this in a rule command to switch it to a different input, what is the syntax for that? i tried sendCommand(com.webos.app.hdmi2) but the syntax checker tells me thats not a valid type for a string item.
someItem.sendCommand("com.webos.app.hdmi2") for a string item.
Syntax gets me everytime. This worked fine. Thanks.
