Have you setup the user/pw properly?
Otherwise HABApp is running fine.
You mean in the config File?
When i type PW and User
im gettin this error:
(habapp) openhabian@openhabian:/opt/openhab/conf/habapp $ sudo nano config.yml
(habapp) openhabian@openhabian:/opt/openhab/conf/habapp $ sudo systemctl restart habapp.service
(habapp) openhabian@openhabian:/opt/openhab/conf/habapp $ sudo systemctl status habapp.service
β habapp.service - HABApp
Loaded: loaded (/etc/systemd/system/habapp.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2021-12-14 19:36:25 CET; 3s ago
Docs: https://habapp.readthedocs.io
Main PID: 2253 (habapp)
Tasks: 7 (limit: 4454)
CGroup: /system.slice/habapp.service
ββ2253 /opt/habapp/bin/python3 /opt/habapp/bin/habapp -c /opt/openhab/conf/habapp
Dec 14 19:36:25 openhabian systemd[1]: Started HABApp.
Dec 14 19:36:26 openhabian habapp[2253]: Error loading logging config: Unable to configure handler 'EventFile'
Dec 14 19:36:26 openhabian habapp[2253]: Executing <Task pending coro=<Runtime.start() running at /opt/habapp/lib/python3.7/site-packages/HABApp/runtime/runtime.py:61> cr
penhabian@openhabian:/var/log/openhab $ sudo systemctl status habapp.service
Active: active (running) since Tue 2021-12-14 19:40:23 CET; 3min 11s ago
Main PID: 783 (habapp)
Tasks: 10 (limit: 4454)
ββ783 /opt/habapp/bin/python3 /opt/habapp/bin/habapp -c /opt/openhab/conf/habapp
Dec 14 19:41:28 openhabian habapp[783]: Executing <Handle <TaskWakeupMethWrapper object at 0xb4b4afd0>(<Future finis...events.py:396>) c
Dec 14 19:42:04 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:42:14 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:42:24 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:42:34 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:42:44 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:42:54 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:43:04 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:43:14 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:43:25 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
Dec 14 19:43:35 openhabian habapp[783]: Status 404 for PUT http://localhost:8080/rest/items/HABApp_Ping/state/ NULL
lines 1-20/20 (END)...skipping...
Dec 14 19:41:28 openhabian habapp[783]: Executing <Handle <TaskWakeupMethWrapper object at 0xb4b4afd0>(<Future finis...events.py:396>) created at /usr/lib/python3.7/asyn
You modified the logging config which now seems to be broken and you are not posting the full HABApp.log file for each corresponding start.
Itβs impossible to help you if you break stuff on purpose.
O_o
Pm me when you have time and weβll take a look at it together
