Thanks for your patience and help - got that clear now. Growing doubts OH3 is not the right version for me then
Why?
Well, you see, I expect to have to spend a lot of time to set up my OH iot solution. The user interface is gorgeous, but brand new. It means for me that everything not implemented correctly by the SW team cannot be fixed easily working behind the scenes in text mode.
Moreover, as I will know more and more the system, I expect to take less time fixing a text file than browsing the UI. That’s the reason complex development environment like for instance the Visual studio suite do not bind you using only the UI.
Take this example today - I was trying to fix a chart adding multiple series, and I cannot get the gridindex working. Series not working simply disappear from the interface and you cannot recover them. Have to delete the whole chart and restart. YAML not helping. I’d like to see the underlying implementation to troubleshoot. not possible, I think.
Or, I need to add many copies of the same thing with minor changes (IDs etc) - a text interface is a winner.
I expected that, even if the underlying ‘engine’ has been moved to JSONDB, an utility to allow to ‘translate’ in and out to the old text language (with potential UI losses I understand, but that’s better than nothing) was provided or planned. If you are locked to the UI and the only chance to work in text is rebuild everything from scratch, well, obviously I don’t feel like getting bound to it.
Users who expect to link just few items and have a quick fix would obviously feel the opposite, I understand. It makes sense.
I am a bit surprised that a system that has Linux as the core target is switching to a full locked UI. Sounds more IOS to me. JMHO.
Now I just need to understand if there is some reason (additional functionalities etc) to run textual OH3 instead OH2.5. Let’s see when I found some documentation on that topic… People I have talked to, so far, tend to stick to 2.5 for this text thing, which I have now understood a bit better
I think, there is a misunderstaning. Yes, you can import your items into JSONDB via UI, but you can also stay at where you are, defining them in text files. This is not going to be removed. Therefore, there is no target to switching to a locked UI.
What might need to be changed though, you may need to add metadata to your items which are introduced with openHAB 3.0.
mhh. so an hybrid system is possible? So the choice mentioned in this page is not really a choice…? Now I am confused
Even openHAB 2 had some kind of a hybrid solution. PaperUI was for graphical config, while there was support for textual as well.
We had bid discussion here in the community, users being afraid of not being able to use textual config any more. This was never on focus.
With the new UI and config handling, we aim to make it simpler for new users, while still give the power users most felixibility with textual config.
Many people here are successfully using text files with OH3. If you use text files you cannot manage those objects through the UI, same as in OH2.
If you wish to use the UI c=you can use scripts or other CLI methods to update things through the REST API, same as the UI does. The UI uses the REST API.
OH has used JSONDB for years. OH 2 uses JSONDB.
All developers here are volunteers. Feel free to propose something in GitHub.
this makes very sense. I justhope to find some documentation somewhere, like the workflow of interactions text-ui - and markups.
That would be a VERY interesting documentation page to read, even before diving in the nitty gritty of the OH model.
Documentation updates are under review und we aim to publish them with the final relase.
It’s all serialized to the JSONDB. You can see the “actual” implementation there, if what you mean is how it’s actually stored. There will be at least one file that starts with “uicomponents_ui”. I think almost everything Pages related gets stored in there.
This is very well supported with Items. And there are discussions for how to handle the rest to do bulk edits. They won’t be ready before OH 3.0 release though.
But I should note that IDs are pretty much universally unchangable. It appears you can easily change IDs when using certain text config files but what is actually happening is everything defined by that file gets destroyed and then recreated anew when the text config is loaded. And even if you do that, stuff can become orphaned. For example, if you change the name of an Item, there are Links, Metadata, Rules, Pages, and Sitemaps that won’t necessarily get updated to use the new Item name.
There is nothing locked about it. Everything is stored as plain text for inspection and potential hand editing should you need to (just don’t edit the JSONDB by hand while OH is running or your changes might get overwritten). And if JSONDB’s a problem for you, there is still support for sitemaps in the UI.
For Things, there are limitations with .things files that do not exist when using the UI to manage Things. One big thing is certain bindings, such as the zwave binding, are not fully functional with .things files. In Zwave’s case, you cannot set parameters on end devices if your things are defined in .things files.
In addition, many of the developers and helpers on this forum (including me) will not provide support for .things files syntax. It’s a huge time sink which simply goes away when you use the UI. The syntax is never wrong when Things are automatically discovered or created through the UI.
As for the rest, they are supported pretty much the same as they were supported in OH 2. They get loaded into memory, overwriting anything that happened to be there before, every time OH starts or the file is changed.
Performance of loading and parsing the text configs has greatly improved in OH 3 but it’s still much faster when using JSONDB for storage.
The majority of people who stick to text configs (not all but most I think) tend to be quite conservative. They’ve been using text based configs for a long time so have a compelling reason not to change, and they tend to be slow to update OH. So just be aware of sample bias for something like this.
I’m not going to tell you one way or the other. But the Getting Started Tutorial isn’t going to help you much if you choose text based configs. And I don’t foresee someone writing such a tutorial anytime soon (I know Yannick and I are not and we’re the primary contributors to the tutorial so far) . So you will have to figure stuff out from the reference docs, the forum, and asking for help. Obviously it can be done and is pretty much how it’s always been done up to this point in OH 1.x and 2.x.
But I want to reemphasize one point. OH 3 does not eliminate any text config options that exists in OH 2.5. You can set up and configure OH 3 exactly the same way if desired.
Note, if something still seems to say OH 2 or be OH 2 focused, it doesn’t really matter because these configs and formats have not changed in OH 3 (except for the metadata stuff already mentioned which I think is mainly a concern for MainUI Pages which, if you are going for a 100% text based config with nothing in JSONDB you would not be using anyway). That just means we the docs contributors haven’t got to that page yet to change some of the references.
File Type | Link | Notes |
Things | Things | openHAB | You’ll need to look at the binding doc for specifics about that binding’s Thing’s options |
Items | Items | openHAB | |
Sitemaps | https://next.openhab.org/docs/configuration/sitemaps.html | |
Persistence | Persistence | openHAB | This is still only supported through text configs in OH 3, but now each persistence add-on comes with a default policy. |
Rules DSL | Textual Rules | openHAB | |
Transformations | Transformations | openHAB | Each transformation will have it’s own syntax as well, see the add-ons docs for details. |
Actions | Actions | openHAB | Certain Actions, like Ephemeris still have only a text based config available. |
JSR223 | JSR223 Scripting | openHAB | If you want to get started with one of the other supported programming languages for rules. |
Notice how all I did to build that table was go to the “Configuration” part of the docs and copy the links on down the line one by one.
EDIT: I should have posted links to next.openhab.org instead of www.openhab.org
Nothing much to add after this great reply. You can go full JSON DB, or none at all, or partly.
Stuff defined in text files won’t be editable in the UI, because the UI will never touch your files. If you know relational databases, think of your files as SQL source files, you run them to bootstrap your tables and views etc. - openHAB actually runs them constantly, removing things and re-adding them as you change them, and the fundamental difference is that those are immutable - and changing things in the UI as making statements to alter a table when it’s live. When you do that, your database engine will not find your original SQL file that you used to bootstrap the database and change it.
With the JSON DB you have the convenience of being able to say whenever you’re on your couch “hey I wish that rule would set this to 30 instead of 40” and pull out your phone and (in many cases) being able to do just that, or, you could prefer to also have the convenience of a full-fledged text editor and have the configuration re-read when you save those source files. You can have a mix of both, you decide.
Ultimately the rule is, “whatever floats your boat”, if you don’t find the UI convenient I for one won’t be offended for sure, if your use case means it’s not the best way.
Just to share my experience in migrating my all text file based OH2 system to OH3 (both Dockers). With almost 400 Items and extensive DSL Rules, Sitemaps, HabPanel and Map files I can say that in my case there were only a few issues that needed to be worked around. As others have said, OH3 treats text files much the same as OH2. I did have to make changes to a few rules that used Joda.time ( thanks rlkoshak) and WOL in OH2 and recreate a few Items that for some reason, still unknown, have no way to link to Things but OH3 is still young. Further for the one binding that I use for which there is no OH3 update, I was able to use the Remote OpenHab binding to federate OH3 with an OH2 install that runs only this single binding. There is some added latency with this approach, but not terrible.
While everything is working fine, I’m still on the fence as to whether to make this my production system NOW, or to wait a bit longer before making the move permanent. In my case OH2 is as solid as a rock and OH3 offers no real benefit TODAY when using text files, sitemaps and HabPanel. However as things change, API’s are updated and Certificates need to be renewed, OH2 will be stranded with little to no support going forward. So from my perspective it really is not whether to migrate but when is the right time to migrate. I am continuing to run OH3 in test mode using text files exclusively and using HabPanel and Sitemaps as my user interface, but OH3 stability is looking better as each day passes. In the meantime I will continue to evaluate Pages as an alternative UI to Sitemaps and HabPanel.
really, hope I have not offended anyone, the UI is great and I know how hard must be developing it. I am just writing as a newbie who needs to understand how to get around and troubleshoot.
Back on the topic with a live example, not sure if this issue OH3 how view textual definition of an Item is linked to that. Integration of the charts in the UI with items: is it supported only if the item is created through the UI for instance?
No, it should be supported either way. I don’t think the UI sees those any differently except that it has to know that Items defined in .items files are read only in the UI. But otherwise two identically configured Items (except with different names of course) should behave the same in the UI including appearance in the automatically generated parts of the Overview Page, appearance in the model, and charting.
Yes you are correct. It looks like there is a known bug which hampers charting for some hours for items created manully - and/or after installing a new persistence (?!) see here for additional insight. Writing for newbies stuck with the same issue trying to follow the tutorial
It might be helpful as well to look at the Persistence Page (Persistence | openHAB) I wrote as part of the tutorial that is not part of this wiki series.
