Getting the mapped string value of a number item
I have a number item in my sitemap:
Selection item=Scene_LivingRoom label="Scene Selector" mappings=[1="OFF", 2="ON", 3="DINNER", 4="READING",5="FIREPLACE", 6="BAR", 7="PARTY", 8="TV",9="COOKING", 10="WALL", 11="KITCHEN", 12="LOUNGE"]
In my rule when the scene change I would like to grab the string mapping(like DINNER) instead of the integer(3) is this possible?
I think that’s not possible when you only have that mappings in the sitemap.
You should create a Transformation file with the same mappings, than you can access them inside a rule like this:
var String textstring = transform(“MAP”, “Mappingfile.map”,Intergervalue.toString)
with the Mallingfile.map
1=OFF
2=ON
3=DINNER
But maybe there is a better approach i don’t know?
Make sense since the call might not just come from the sitemap! I will move it to a mapping file. That will work for me, thanks
Maybe its late, but shouldnt this work in the sitemap?
Switch item=Scene_MasterBedRoom label="Scenes [MAP(masterBedRoom.map):%s]"
with this map.file:
0="OFF"
1="ON"
2="NIGHT"
3="READING"
as far as i know, the label text can’t be changed dynamically… That’s a different approach than you posted before!
A workarround is to use multiple items with different visibility to “change sitemap items dynamically”
Something like that:
Image url="http://localhost:8080/rrdchart.png?items=presence,group_presence&period=D&w=800" refresh=60000 visibility=[period == 0]
Image url="http://localhost:8080/rrdchart.png?items=presence,group_presence&period=W&w=800" refresh=60000 visibility=[period == 1]
Image url="http://localhost:8080/rrdchart.png?items=presence,group_presence&period=M&w=800" refresh=60000 visibility=[period == 2]
Image url="http://localhost:8080/rrdchart.png?items=presence,group_presence&period=Y&w=800" refresh=60000 visibility=[period == 3]
I used to have mapping like this:
Switch item=Scene_MasterBedRoom label="Scenes" mappings=[1="OFF", 2="ON", 3="NIGHT", 4="READING"]
but I am reading up on the documentation, but I can not find a clear example how to do it:
sitemap
transfomation
transformation service
last one said : Usage of Transformations in the label parameter of Sitemap elements works the same way, and it links you here:
Text item=Temperature label="Livingroom [%.1f °C]" icon="temperature"
I assume it should be
Switch item=Scene_MasterBedRoom label="Scenes " mappings=[masterBedRoom.map] where the mapping file needs to be in any subfolder in the transformation folder catatlog…
I find it on this topic hard to read the documentation, maybe we could rewrite it @Kai? I could help on it, just need some input.
Also the rest of the sitemap documentation uses full examples while mappings not:
mappings=[value_1="description_1", value_2="description_2", ...] vs
Video [item=<itemname>] [icon="<iconname>"] url="<url of video to embed>" [encoding="<video encoding>"]
We should rewite it to :
Switch item=dummyItem label="DummyLabel" mappings=[value_1="description_1", value_2="description_2", ...]
to keep it consistent through out the documentation
