after updating to the latest nightly build #385 I have double entries within the paperUI and also German special characters seem to have a problem. I don’t know if it is the build or if my update procedure is wrong. It also seems I can’t delete the “ghost lamps”.
Hue lamps are not functioning anymore from basicUI most likely caused by those ghosts.
For update (Windows 10) I stop openhab and delete the runtime folder and the content of the userdata/cache and userdata/tmp folder. Then I extract the build to the openhub directory overiding everything. Then I copy my backuped addons.cfg and runtime.cfg to the updated openhab folder and restart openhab.
Next to the update procedure in my first post I also deleted all lights within the .items file and deleted all lamps and the bridge within the paperUI and restarted openHAB but still I have those ghosts. I don’t use a Things file. Sorry for my newbisch question but what else do I need to delete to get rid of them?
If a thing is in “REMOVING” status, you should be able to simply click the trash icon a second time and you should be asked if you really want to remove it. Have you tried that?
