Platform information:
- Hardware: Raspberry Pi 3
- OS: OpenHabian
- Java Runtime Environment: OpenJDK Runtime Environment (Zulu embedded 8.25.0.76 (build1.8)
- openHAB version: 2
Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
If logs where generated please post these here using code fences:
Iâve added the GC-100 from searching for it as a Thing, I have tried to send a simple IR command to a receiver on 5:3 (fifth connector, third IR port )
Iâve tested the command through iTest from GlobalCache and it works and blinks the light on the back of the GC-100. But when I try the command in OH2 it doesnât seem to work as it doesnât blink the light to confirm the command was sent.
I tried an auto config, then I created a Widget in HABPanel then gave it the initial command. I tried two commands:
For Power On:
First Command Tried:
sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772
Second Command Tried:
My Log File: /var/log/openhab2/openhab.log
2017-12-14 11:04:29.477 [WARN ] [rm.AbstractFileTransformationService] - Could not transform âONâ with the file âglobalcacheir.mapâ : Target value not found in map for 'ONâ
2017-12-14 11:04:29.479 [WARN ] [obalcache.handler.GlobalCacheHandler] - No entry for ON in map file âglobalcacheir.mapâ for thing gc100_12:000C1EC01A8A
2017-12-14 11:04:30.221 [WARN ] [rm.AbstractFileTransformationService] - Could not transform âsendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â with the file âglobalcacheir.mapâ : Target value not found in map for 'sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â
2017-12-14 11:04:30.226 [WARN ] [obalcache.handler.GlobalCacheHandler] - No entry for sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772 in map file âglobalcacheir.mapâ for thing gc100_12:000C1EC01A8A
2017-12-14 11:04:59.588 [WARN ] [rm.AbstractFileTransformationService] - Could not transform âsendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â with the file âglobalcacheir.mapâ : Target value not found in map for 'sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â
2017-12-14 11:04:59.592 [WARN ] [obalcache.handler.GlobalCacheHandler] - No entry for sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772 in map file âglobalcacheir.mapâ for thing gc100_12:000C1EC01A8A
2017-12-14 11:05:01.830 [WARN ] [rm.AbstractFileTransformationService] - Could not transform âsendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â with the file âglobalcacheir.mapâ : Target value not found in map for 'sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772â
2017-12-14 11:05:01.835 [WARN ] [obalcache.handler.GlobalCacheHandler] - No entry for sendir,5:3,1,38000,1,1,218,111,72,217,72,72,72,772 in map file âglobalcacheir.mapâ for thing gc100_12:000C1EC01A8A
Can you post the contents of your transform/globalcacheir.map file?
The map file should contain something similar to this.
SONYTV_POWER_ON = 40000,2,1,96,24,24,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,1014
SONYTV_POWER_OFF = 40000,2,1,96,24,48,24,48,24,48,24,48,24,24,24,48,24,24,24,48,24,24,24,24,24,24,24,24,990
The item should look sometyhing like this (modified for the gc100 module/connector).
String Kitchen_TV "Kitchen TV" { channel="globalcache:itachIR:000C1E0391E5:ir-m1#c1" }
And the HABpanel should look something like this.
Hey Thanks for the quick response mhilbush
I will try that
btw, I got it to toggle the power through a âswitch widgetâ I didnât have to enter the command with this but at least I know it sent a command and I am closer to getting to know how to send all the commands!! I think I only have about less than 10 commands to sendâŠ
It worked, thanks!!
Mark, are you just a user of OpenHAB or one of the contributors of OpenHAB or ???
I really appreciate the support, I love this project I would like to do something to contribute back.
Thanks again. The little bit of help you gave me allowed me to get to the next step, so I am making more progress on my own now.
Yes and yes.
Iâve contributed a couple bindings (GlobalCache, BigAssFan), working on a couple more (SharpTV, SunsetWx), log issues when I find problems, and help out here on the forum.
