aused by: java.net.UnknownHostException: smtp.gmail.com
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184) ~[na:1.8.0]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[na:1.8.0]
at java.net.Socket.connect(Socket.java:589) ~[na:1.8.0]
at java.net.Socket.connect(Socket.java:538) ~[na:1.8.0]
at java.net.Socket.<init>(Socket.java:434) ~[na:1.8.0]
at java.net.Socket.<init>(Socket.java:286) ~[na:1.8.0]
at org.apache.geronimo.javamail.transport.smtp.SMTPTransport.getConnectedSocket(SMTPTransport.java:1096) ~[na:na]
at org.apache.geronimo.javamail.transport.smtp.SMTPTransport.getConnection(SMTPTransport.java:856) ~[na:na]
at org.apache.geronimo.javamail.transport.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:385) ~[na:na]
... 36 common frames omitted
i copied the mail. binding into addons and used this setting in the config file
######################## Mail Action configuration ####################################
# The SMTP server hostname, e.g. "smtp.gmail.com"
mail:hostname=smtp.gmail.com
# the SMTP port to use (optional, defaults to 25 (resp. 587 for TLS))
mail:port=587
# the username and password if the SMTP server requires authentication
mail:username=xxxxxx
mail:password=xxxxxx
# The email address to use for sending mails
mail:from=xxxxx@gmail.com
# set to "true", if TLS should be used for the connection
# (optional, defaults to false)
mail:tls=true
# set to "true", if POP before SMTP (another authentication mechanism)
# should be enabled. Username and Password are taken from the above
# configuration (optional, default to false)
#mail:popbeforesmtp=
pi@raspberrypi ~ $ sudo apt-get install dnsutils
Reading package lists... Done
Building dependency tree
Suggested packages:
rblcheck
The following NEW packages will be installed:
dnsutils
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 162 kB of archives.
After this operation, 309 kB of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
dnsutils
Install these packages without verification [y/N]? y
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main dnsutils armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u7
Something wicked happened resolving 'mirrordirector.raspbian.org:http' (-5 - No address associated with hostname)
Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/b/bind9/dnsutils_9.8.4.dfsg.P1-6+nmu2+deb7u7_armhf.deb Something wicked happened resolving 'mirrordirector.raspbian.org:http' (-5 - No address associated with hostname)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
pi@raspberrypi ~ $ nslookup smtp.google.com
-bash: nslookup: command not found
ping smtp.gmail.com
PING gmail-smtp-msa.l.google.com (64.233.162.108) 56(84) bytes of data.
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=1 ttl=45 time=35.9 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=2 ttl=45 time=45.0 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=3 ttl=45 time=41.0 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=4 ttl=45 time=39.9 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=5 ttl=45 time=49.9 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=6 ttl=45 time=43.6 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=7 ttl=45 time=49.8 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=8 ttl=45 time=48.5 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=9 ttl=45 time=43.3 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=10 ttl=45 time=243 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=11 ttl=45 time=67.8 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=12 ttl=45 time=42.1 ms
64 bytes from li-in-f108.1e100.net (64.233.162.108): icmp_req=13 ttl=45 time=36.1 ms
