Hello, in researching an issue I’m having with my RGBW dimmer, I found this thread, describing the same issue I’m experiencing. When I try to change the color value on the dimmer, in the logs I see the error “[WARN ] [nternal.converter.ZWaveColorConverter] - NODE 21: Unknown color mode null”.
I checked the Zwave device database and found this in the configuration file:
<channel id="color_color" typeId="color_color"> <label>Color Control</label> <properties> <property name="binding:*:HSBType">COMMAND_CLASS_SWITCH_COLOR</property> <property name="binding:*:PercentType">COMMAND_CLASS_SWITCH_MULTILEVEL</property> <property name="binding:Command:OnOffType">COMMAND_CLASS_SWITCH_MULTILEVEL</property> </properties> </channel> <channel id="color_temperature" typeId="color_temperature"> <label>Color Temperature</label> <properties> <property name="binding:*:PercentType">COMMAND_CLASS_SWITCH_COLOR;colorMode=DIFF_WHITE</property> <property name="binding:Command:OnOffType">COMMAND_CLASS_SWITCH_MULTILEVEL</property> </properties> </channel>
According to that linked thread, it sounds like colorMode should be “RGB”. Is that correct? If so, can we get that changed? Are there any other possible solutions?
As always, thanks for your help.
Running OH 2.5.0
