Hello, I’ve created a group to control it’s members. I want to switch the lights on and off and dim them via Google Assistant. The on/off part works, but the dim switches the lights off. Looking in the logs a 0 command is triggerd with the dim command.
Item 'gHueBrightnessWoonkamer' received command 0
Is there something wrong with my group definition, or is this an Google Assistant Action issue?
My items file:
Group:Dimmer gHueBrightnessWoonkamer "Woonkamer lampen" [ "Lighting" ]
Dimmer Hue_Brightness_Woonkamer_Eettafel_1 "Dimmer [%s]" (gHueWoonkamer, gHue, gHueBrightnessWoonkamer) { channel="hue:0200:0017887a599e:12:color" }
Dimmer Hue_Brightness_Woonkamer_Eettafel_2 "Dimmer [%s]" (gHueWoonkamer, gHue, gHueBrightnessWoonkamer) { channel="hue:0200:0017887a599e:13:color" }
Dimmer Hue_Brightness_Woonkamer_Leeslamp_1 "Dimmer [%s]" (gHueWoonkamer, gHue, gHueBrightnessWoonkamer) { channel="hue:0200:0017887a599e:3:color" }
