I was looking for an easy way to setup broadcast to our google homes from OH. I found this project on github and it was a breeze to setup.
This tutorial assumes you have a project setup on the Google Developers console, and you’ve enabled the Google Assistant API, created credentials, and downloaded your client secret.
- Make sure you have Node installed from https://nodejs.org/en/
- Install PM2 as a pre-requisite if not already installed
sudo npm i pm2 -g
- Download a copy of the latest release from https://github.com/greghesp/assistant-relay/releases and then use
npm i
to get started. Once setup, runnpm run start
. You do NOT want the source files- Navigate to the webpage shown and follow the configuration instructions. It should be http://server-ip:3000
- Run some tests in the sand box to confirm communication with your GH’s
- Create the rules below. Be sure to update your sever ip.
- Add ‘String broadcast’ and ‘String ghCommand’ to an item file
- You can test by adding the follwing to a sitemap.
Switch item=broadcast mappings=[“lunch”=“Lunch”,“bedtime”=“Bed Time”,“movietime”=“TV Time”]
rule “broadcast”
Item broadcast received update
var message = broadcast.state.toString
var command
switch (message) {
case “wakeup”: command = ‘{“preset”:"’+ message +’"}’
case “breakfast”: command = ‘{“preset”:"’+ message +’"}’
case “lunch”: command = ‘{“preset”:"’+ message +’"}’
case “dinner”: command = ‘{“preset”:"’+ message +’"}’
case “timetoleave”: command = ‘{“preset”:"’+ message +’"}’
case “arrivedhome”: command = ‘{“preset”:"’+ message +’"}’
case “ontheway”: command = ‘{“preset”:"’+ message +’"}’
case “movietime”: command = ‘{“preset”:"’+ message +’"}’
case “tvtime”: command = ‘{“preset”:"’+ message +’"}’
case “bedtime”: command = ‘{“preset”:"’+ message +’"}’
default : command = ‘{“command”:"’+ message +’",“broadcast”:“true”}’
sendHttpPostRequest(“http://server-ip:3000/assistant”, “application/json”, command )
logInfo(“Broadcast”, “Message Sent:”+message)
rule “Google Command”
Item ghCommand received update
var command
command = ‘{“command”:"’+ message +’"}’
sendHttpPostRequest(“http://sever-ip:3000/assistant”, “application/json”, command )
logInfo(“Broadcast”, “Command Sent:”+message)
Update the Broadcast item to broadcast to your GH network, and update the ghCommand item with any command you could speak to your GH.
One note, which is a bit annoying, is it adds a “User says…” to any custom broadcast and some presets, where User is the first name of the google user account the project is setup under. I created a separate account and changed the first name to Openhab so everyone knows when its a system message.
