I have the caldav bindings installed and configurated…
Under /services i have the caldavio.cfg
caldavio:Muellabfuhr:url=https://www.google.com/calendar/dav/xxx@group.calendar.google.com/events
caldavio:Muellabfuhr:username=username
caldavio:Muellabfuhr:password=app-password
caldavio:Muellabfuhr:reloadInterval=1
caldavio:Muellabfuhr:preloadTime=20000
caldavio:Muellabfuhr:disableCertificateVerification=true
I also have a caldavPersonal.cfg
caldavPersonal:usedCalendars=caldavio:Muellabfuhr
Under /userdata/config/org/openhab/caldavio.config
:org.apache.felix.configadmin.revision:=L"1"
Muellabfuhr:disableCertificateVerification="true"
Muellabfuhr:password="app-password"
Muellabfuhr:preloadTime="20000"
Muellabfuhr:reloadInterval="1"
Muellabfuhr:url="https://www.google.com/calendar/dav/xxx@group.calendar.google.com/events"
Muellabfuhr:username="username"
service.pid="org.openhab.caldavio"
and also a caldavPersonal.config
:org.apache.felix.configadmin.revision:=L"3"
service.pid="org.openhab.caldavPersonal"
usedCalendars="caldavio:Muellabfuhr"
After starting OH everthings seems to be fine, the first event is recognized.And also under /userdata/etc/caldav/ the new folder is built
But then the errors starts and the items are not updated.
2019-08-23 15:30:10.233 [WARN ] [caldav.internal.job.EventReloaderJob] - Sardine exception reading ics file: abfuhrkalender_srhh_de_44_1563224074555
com.github.sardine.impl.SardineException: Unexpected response
at com.github.sardine.impl.handler.ValidatingResponseHandler.validateResponse(ValidatingResponseHandler.java:48) ~[293:org.openhab.io.caldav:1.14.0.M2]
at com.github.sardine.impl.handler.VoidResponseHandler.handleResponse(VoidResponseHandler.java:34) ~[293:org.openhab.io.caldav:1.14.0.M2]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:756) ~[293:org.openhab.io.caldav:1.14.0.M2]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:741) ~[293:org.openhab.io.caldav:1.14.0.M2]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:732) ~[293:org.openhab.io.caldav:1.14.0.M2]
at com.github.sardine.impl.SardineImpl.get(SardineImpl.java:145) ~[293:org.openhab.io.caldav:1.14.0.M2]
at org.openhab.io.caldav.internal.job.EventReloaderJob.loadEvents(EventReloaderJob.java:323) [293:org.openhab.io.caldav:1.14.0.M2]
at org.openhab.io.caldav.internal.job.EventReloaderJob.execute(EventReloaderJob.java:141) [293:org.openhab.io.caldav:1.14.0.M2]
at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [181:org.openhab.core.scheduler:2.5.0.M2]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [181:org.openhab.core.scheduler:2.5.0.M2]
I also deleted all the config files and did a restart, but this didn´t help…
Has somebody an idea ?
