Hi all,
I´ve decided to start here an example on how to display charts using different y-axis with google API. As I try to make this a more detailed one than my usual inspirations, this post will not yet contain the full example; but the result. I´ll later add step by step on what was required to get there.
The result; a chart with multi x-axis supporting zoom to pre-defined steps:
Preparations
Folder Structure
Create the following sub-folders in your installations html directory:
- css
- javascript
- Visualization
Please the following file in the .css folder:
- visualizationStyle.css (482 Bytes)
The following files are to be placed in the “javascript” sub-folder:
- openHAB.js.xml (4.0 KB)
- jquery.csv.min.js.xml (8.1 KB)
- date.js.xml (25.2 KB)
The following file needs to be placed in the “Visualization” folder:
- MultiLineDualYChart.html.xml (8.0 KB)
Note: You´ll need to remove the .xml extension - the file must end .js, or .html respectively (but this file type can not be uploaded here …)
Configuration
HTML
The items to plot are hardcoded in the .html file; search the function “DrawChart” and replace the item list with the your items (you may also, remove or add items):
As a next step we define how many y-axis we need; search the “chartOptions”. There you can configure the different axis. The example below uses three axis (only two of them visible):
Every openHAB item you have registered earlier represents a series. For series that do not use the default y-axis you´ll need to add configuration entires too:
Sitemap
Last but not least add the diagram to the sitemap:
Webview url="/static/Visualization/MultiLineDualYChart.html?days=14&serviceId=rrd4j" height=4
with kind regards,
Patrik
