Issue of the topic: google home and a denon receiver. How to select a source for the receiver?
I have google home, open hab and my denon-marantz-binding all working for power and mute from my google home to my receiver?. How can i get my google home to work with selecting a source? I only want to be able to select 2 sources. Game or cbl/sat. I do not need all the sources to work, only the 2. So I thought a switch could do the trick? If I am able to say any source and that way would work, that would be ok too.
I tried the following, but it does not work. I tried different switch/strings and other ideas that do not work?
String marantz_input “Input [%s]” (Media,Livingroom) [ “Lighting” ] {channel=“denonmarantz:avr:1:mainZone#input” }
Can some one show me the way? I thought about a rule/script, but do not see how that can work with google home.
FYI, I was a home-assistant user and I have this working, but I am trying out openhab to see what i like more.
I tried to make a http binding switch, tell me if that does not work, but there are no errors in the log, but i do not see the switch in my paper iu. Anything wrong here?
rule “HeizungNachtWohnenAus”
Item yourTriggerSwitch received command ON
sendHttpGetRequest(“http://IP:PORT/set/thermostat/ABBxxxxx/ch0000/off”) //Wohnzimmer
This as in my other test code, does not show up on the paper ui control page? Am i wrong in the concept that the control page should show all switches?
Hi Marc,
many thanks for you “SAT/CBL” hack - it saved me much time looking for “CBL/SAT” (which I renamed and used for “Apple TV”) in my Home Assistant setup.
Originally I started from here: subutux/denonavr/blob/master/CommandEndpoints.txt
