I’m trying to get google home to work with all(most) of my openhab devices. But I am stumbling on an issue with the shutters.
I have created the following item: Rollershutter F2_Slaapkamer_Shutter "Slaapkamer Shutter" <blinds> (F1_gBlinds) {channel="zwave:qubino_zmnhcd_00_000:zcontroller:node50:blinds_control", ga="Shutter" [ inverted=true ]}
But when I ask google to close the shutter it closes the shutter as expected, but when I ask to open the shutter Google says it’s opening the shutter I hear the Qubino clicking but when I check the login from Openhab it gets the command to close the shutter. When I place the command invert in the item file it does the something only with UP instead of Down.
I noticed that somewhere the commands aren’t translated well I guess. Apparently, it does not recognize the command UP (in dutch) only Down:
Command Shutter >UP<
2020-10-11 10:38:29.737 [ome.event.ItemCommandEvent] - Item ‘F2_Slaapkamer_Shutter’ received command DOWN
2020-10-11 10:38:29.738 [nt.ItemStatePredictedEvent] - F2_Slaapkamer_Shutter predicted to become DOWN
Command Shutter >Down<
2020-10-11 10:39:08.307 [ome.event.ItemCommandEvent] - Item ‘F2_Slaapkamer_Shutter’ received command DOWN
2020-10-11 10:39:08.307 [nt.ItemStatePredictedEvent] - F2_Slaapkamer_Shutter predicted to become DOWN
Command Shutter >Open<
2020-10-11 10:39:43.175 [ome.event.ItemCommandEvent] - Item ‘F2_Slaapkamer_Shutter’ received command UP
2020-10-11 10:39:43.175 [nt.ItemStatePredictedEvent] - F2_Slaapkamer_Shutter predicted to become UP
Command Shutter >Close<
2020-10-11 10:40:09.452 [ome.event.ItemCommandEvent] - Item ‘F2_Slaapkamer_Shutter’ received command DOWN
2020-10-11 10:40:09.453 [nt.ItemStatePredictedEvent] - F2_Slaapkamer_Shutter predicted to become DOWN
Is this a bug or is google translating this wrong?
