@rgerrans I am having the same problem as you, although I do have a physical Google Home device. When I try pair with the hue it takes me to hue-adapter.appspot.com then I get Couldn’t find Hue Bridge. I have tried both with the current version of the Google Home app and the older one listed in another post. If I use a UPnP browser on my phone it is able to see the "openHAB Hue Emulation. My ports are forwarded to 80 and accessible from there. I’m running on a standard installation of RaspbianPi which should have no firewall blocking anything.
I am in Australia, but my GHome and Android device are set to US (imported GHome before it was available here).
It does seem strange how some people seem to get it working with no problem and others battle…
So much for that theory. Something else obviously going on then…
I had the same probelems, by using my iphone to connect google home with the emulated hue bridge. After using my android tablet it worked. With iphone I had to sign in to phillips hue, with the android tablet I don’t have to sign in.
Hi, same Problems here. Can not connect to the emeulated Hue-Bridge. Always went to meethue.com…
also it is a little bit difficult to prevent Google Home to switch off all items discovered through the Hue bridge. I for example use the following items with Alexa:
- Siren
- Rollershutter
- Lights
- Doors
- Sprinkler System
The problem with the command “turn the lights on” all of these devices will be enabled. Any idea to prevent this behaviour?
I tried to create specific rooms like the light room with all lights inside but Google Home turns all the time all discovered devices on and off
Also I still miss the dimming funtion. Why this is not working here but with Alexa?
best regards René
I’ve also had issues where GH could not find the bridge and was getting “Couldn’t find Hue Bridge” no matter what i tried. For whatever reason I also could not get GH working with my ecobee thru “wink” as it was saying “Device is not setup”.
I’ve then tried to do factory reset on GH (15s holding of mute button) and when it came back up all devices got added perfectly and now both Openhab (hue emu) and ecobee (thru wink) are working without any issues.
Hopefully this works for someone else as well.
I’ve tried resetting GH as well, but i still cant connect to Philips Heu Emulation.
How do you enter the rollershutter into HueEmulator?
I am also having trouble with Dim the light and the Brighten the light. Is anyone using these commands with success?
Same here, also not working for me. I asked somewhere else as well but still haven’t found anyone for which it’s working.
Please help. I have Google Home Hue Emulator running and paired. But I don’t see my Z-wave devices in Google Home app. http://openhabian/api/discover.xml displays: {“lights”:{}}
Reading the README it says. Device tagging. How do I do it?
Hi i upgraded to 2.20 and followed everything but even though my G home app recognizes the hue bridge emulation, it ask me to press the link button on the bridge and eventually times out. Please help me and I greatly appreciate it.
PS. I have paring enabled and i changed it to port 80 in paper ui but is there a way i can manually press the emulation’s button or something , Im pretty new to all of this. thanks in advance Amit.
did anybody find a way to avoid this?
same happens to me
So, I’m also having the same issue as everyone else with no devices found during the scan. Everything is set up as I’ve read elsewhere.
Have checked:
- Port 80 is open
- Have output from api/discover.xml as below
I’m attempting from Australia, not sure if that matters. Really wondering if Philips have blocked Openhab at the discovery stage.
{"lights":{"Spot_Light1":{"state":{"on":true,"bri":255,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"On Off","modelid":"LWB004","uniqueid":"Spot_Light1","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}},"Spot_Light2":{"state":{"on":true,"bri":255,"hue":0,"sat":0,"xy":[0.0,0.0],"ct":500,"alert":"none","effect":"none","colormode":"ct","reachable":true},"type":"Dimmable Light","name":"Brightness","modelid":"LWB004","uniqueid":"Spot_Light2","manufacturername":"openHAB","swversion":"66009461","pointsymbol":{"1":"none","2":"none","3":"none","4":"none","5":"none","6":"none","7":"none","8":"none"}}}}
Port 80 is open, but to speak with openhab you have to direct port 80 to 8080.
I’m sure there are tutorials in this thread on how to do that.
Sorry wasn’t clear, I’ve port forwarded via NGINX, and I can access OH via port 80.
Must I leave the stable version to get this to work?
/Mike
I’m having problems getting this to be discovered.
I have Hue Emulation settings defined as:
- Pairing Enabled
- Web Discovery Port: 80
- Discovery Address defined as my rpi’s ip (192.168.2.3)
Within the rPi i have iptable configured to redirect port 80 to 8080:
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 8080
When attempting to discover the Hue (emulator) bridge within Google Home, the discovery fails. I have downloaded the Hue App from google play and attempted to discover the bridge as well – no luck.
The address i’m being sent to when attempting to add/discover the Hue Bridge within Google Home is https://account.meethue.com
Has anyone had any luck getting this to work.. any suggestions/ideas i should try?
This is not working any more
Hello @Kai,
apparently this solution doens’t work anymore. Do think any other workaround may be possible?
Greetings,
Patrick
