Enebacken
(Lennart Winbladh )
February 11, 2019, 10:16pm
#1
Google home rounds off my temperature which I read from openhab. For example, my indoor temp is 21.3°C then google home shows 21.5°C, if the temperature is 21.8°C then 22°C is shown. Is this rounding something that is possible to switch off?
H102
(CM6.5 H102)
February 12, 2019, 1:46am
#2
Something fishy?? Just read, and linked your post to this topic.
I have setup my Max! thermostats for control via Alexa, and it works quite well, but I have a strange rounding effect that I don’t know how to get rid of:
I say, “Alexa, setze die Temperatur im Wohnzimmer auf 21,5 Grad” ("Alexa, set living room temperature to 21.5 degrees)
Alexa replies, “Automatischer Modus ist auf 22 Grad gestellt” (“Automatic mode is set to 22 degrees”)
The thermostat, however, is correctly set to 21.5 degrees.
Now when I ask, “Alexa, auf was ist Temperatur im Wohnzimmer …
metin
(Metin)
February 12, 2019, 7:56am
#3
Can‘t imagine how this could be connected. Symptoms are different also.
vzorglub
(Vincent Regaud)
#4
It might be worth asking Google. OpenHAB is doing what it is told to.
