As the title states, I have one particular instance of openhab that will won’t register my Pixel 6 under devices when I log in remotely. Everything works fine over the app and I can access everything. I tried logging into this instance with an iPad and that registered just fine. I have a separate instance of openhab running that my pixel registers just fine when I logged into it… I searched and found a couple people that had similar problems(all several years old) and it seemed that the solution was to remove the “/” from the end of “https://myopenhab.org/”, when I attempt to remove it “https://myopenhab.org” and hit save after removing the forward slash, it doesn’t actually change, it reverts back to “https://myopenhab.org/”. So that solution obviously doesn’t work for me. My phone is up to date as is the app. I even tried deleting the app and reinstalling it, with no effect. Any help would be appreciated!!
