When I press on the main menu of my Android phone on the mic google translates my speech to text. Then the GUI shows the message :“Herkend command: (the speech to text message)” (in English will be something like “Known command: (the speech to text message)”
I selected the Rule-based Interpreter.
For a test I added to one switch ga="hoeklamp [inverted=true] assuming that the message hoeklamp would switch the lamp on or off depending on the state but that isn’t happening.
How to debug this or is this wrong.
Switch Woonkamerhoeklamp "Woonkamerhoeklamp" <switch> (BG_Woonkamer) ["PowerOutlet"] {channel="remoteopenhab:server:70b4f651a3:RFXWoonkamerhoeklamp_Command", ga="hoeklamp [inverted=true]"}
When I select HABot OpenNLP Interpreter than I get a error http code 400
