Just configured google text-to-speach using the docs. Everything seems to work because i can see the following in the logs:
2019-02-07 19:14:48.486 [INFO ] [clipse.smarthome.model.script.speach] - komt eraan
2019-02-07 19:14:48.490 [DEBUG] [.googletts.internal.GoogleTTSService] - Synthesize 'waarom niet?' for voice 'googletts:nlNLStandardA' in format AudioFormat [codec=MP3, container=NONE, bitDepth=16, bitRate=64000, frequency=44100]
2019-02-07 19:14:48.591 [DEBUG] [ce.googletts.internal.GoogleCloudAPI] - Caching audio file nlNLStandardA_f2fe393f1a13fb5ba06b2450a275dbfb.mp3
2019-02-07 19:14:48.594 [DEBUG] [ce.googletts.internal.GoogleCloudAPI] - Caching text file nlNLStandardA_f2fe393f1a13fb5ba06b2450a275dbfb.txt
2019-02-07 19:14:48.953 [INFO ] [clipse.smarthome.model.script.speach] - is geweest
the loginfo doesn’t show any errors and it says the mp3 has been cashed. When i try playing sound to the same chromecast audio it does work, so the CC is ok.
Any thoughts?
EDIT: OK, just changed the command to :“say(“waarom niet?”,“googletts:nlNLStandardA”, new PercentType(100))”. Now when i trigger the rule i can hear not a normal chirp from the chromecast but more something like morse dots in two tones and then something that resembles a burp, but very quiet. I kid you not.
When i change the text to be spoken to a longer tekst and listen very well at 100% volume i can make out the first one or two words very quiet in very poor quality and then it stops, even though te text is 8 words long??? Again when playing mp3 with playSound() everything workes as expected.
EDIT2: for some mistirious reason the quality got better, but the volume is still really low, much lower then using playSound(). vollume is set to max in TTS configuration using paperUI
