I recently bought a Google WiFi and connected it to my existing router (not in bridge mode) and as soon as it comes online I connected some of my wireless devices and thought of adding network things that it will discover via PaperUI, but to my disappointment the connected devices from Google WiFi was not discovered or showing up.
Is there a way network binding to discover connected devices from Google router?
I think you would need to configure the Google WiFi device as only an Access Point and turn on DCHP. The reason the Network Binding can’t see those devices is that they are on a separate subnet and the Network binding is only able to discover devices on the same subnet.
If you assign static IPs on the devices connected to the Google Wifi, you should be able to manually create the Things and it should work.
