GoogleAssistent Meta in items file?
Hi folks,
is it possible to make GoogleAssistent configuration as meta information during a items-file configuration? In case its true, give a example (with define a room, typle and name) plaese…
Also I looking forward for a solution to set “Default List Item” properties by items-file-configuration.
Best regards
Switch Livingroom_Light "Livingroom Ceiling Light" <myswitch> { ga="Switch" [ inverted=false ], roomHint="Living Room"  }
How does google know, thats for assistent and not for amazon alexa?
see
https://github.com/openhab/openhab-google-assistant/blob/main/docs/USAGE.md#item-configuration
vs.
https://github.com/openhab/openhab-alexa/blob/main/docs/USAGE.md#single-endpoint
Different metadata tags ( ga= vs. alexa= ) are used to expose items to one or the other.
