Is there an issue with the openhabcloud service right now. Trying to sync devices and i get an error could not sync your devices, check your connection. For the last week i have been able to sync correctly, just tonight when trying to add items it wont work.
Unlinking and relinking will not work either
Did u fix this problem? Having same/ similar problems. In case u are still searching you need to have labels on any items that are tagged.
Thanks. Yes i figured out afterwards.
