Thank you for your assistance.
I followed your instructions. Google billing and account is operational (i see billing information according to my requests with success).
After creation the rule and running it this is exception during first run (no wav files are created):
2021-11-12 17:33:01.076 [ERROR] [ce.googletts.internal.GoogleCloudAPI] - Could not write /openhab/userdata/cache/org.openhab.voice.googletts/enUSStandardA_33c9e5af4e05b6de0e942a019aa586d5.wav to cache
java.io.IOException: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@1243140::DecryptedEndPoint@124c5fa{l=/172.17.0.4:41086,r=texttospeech.googleapis.com/172.217.16.42:443,OPEN,fill=-,flush=-,to=529239/0}
at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:260) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:155) ~[?:?]
at org.openhab.core.io.net.http.HttpUtil.executeUrl(HttpUtil.java:130) ~[?:?]
at org.openhab.core.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.synthesizeSpeechByGoogle(GoogleCloudAPI.java:425) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.synthesizeSpeech(GoogleCloudAPI.java:334) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleTTSService.synthesize(GoogleTTSService.java:331) ~[?:?]
at org.openhab.core.voice.internal.VoiceManagerImpl.say(VoiceManagerImpl.java:223) ~[?:?]
at org.openhab.core.automation.module.media.internal.SayActionHandler.execute(SayActionHandler.java:60) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1183) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1035) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runNow(RuleEngineImpl.java:1051) ~[?:?]
at org.openhab.core.automation.rest.internal.RuleResource.runNow(RuleResource.java:327) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.3]
Caused by: java.util.concurrent.ExecutionException: java.io.EOFException: HttpConnectionOverHTTP@1243140::DecryptedEndPoint@124c5fa{l=/172.17.0.4:41086,r=texttospeech.googleapis.com/172.217.16.42:443,OPEN,fill=-,flush=-,to=529239/0}
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:730) ~[bundleFile:9.4.40.v20210413]
at org.openhab.core.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:251) ~[?:?]
... 68 more
Caused by: java.io.EOFException: HttpConnectionOverHTTP@1243140::DecryptedEndPoint@124c5fa{l=/172.17.0.4:41086,r=texttospeech.googleapis.com/172.217.16.42:443,OPEN,fill=-,flush=-,to=529239/0}
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.earlyEOF(HttpReceiverOverHTTP.java:376) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1614) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.shutdown(HttpReceiverOverHTTP.java:259) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:181) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) ~[bundleFile:9.4.40.v20210413]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[bundleFile:9.4.40.v20210413]
... 3 more
2021-11-12 17:33:01.157 [WARN ] [core.voice.internal.VoiceManagerImpl] - Error saying 'Hello Google': Could not read from Google Cloud TTS Service
org.openhab.core.voice.TTSException: Could not read from Google Cloud TTS Service
at org.openhab.voice.googletts.internal.GoogleTTSService.synthesize(GoogleTTSService.java:333) ~[?:?]
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.3]
... 68 more
... 3 more
Next runs don’t produce errors in openhab.log. Files are generated now:
pi@raspberrypi:/opt/openhab/userdata/cache/org.openhab.voice.googletts $ ls -la
total 68
drwxrwxrwx 2 openhab openhab 4096 Nov 12 17:48 .
drwxr-xr-x 5 openhab openhab 4096 Nov 10 18:44 ..
-rw-r--r-- 1 openhab openhab 106 Nov 12 17:48 enUSStandardA_33c9e5af4e05b6de0e942a019aa586d5.txt
-rw-r--r-- 1 openhab openhab 53804 Nov 12 17:48 enUSStandardA_33c9e5af4e05b6de0e942a019aa586d5.wav
I’ve checked OpenHAB container ip address:
pi@raspberrypi:~ $ sudo docker inspect -f '{{range.NetworkSettings.Networks}}{{.IPAddress}}{{end}}' 0c1a7d63850e
172.17.0.4
So it looks, that OpenHAB in docker container has problems with connectivity/cross-connectivity. But a little bit strange is, that file is finally donwloaded, but still cannot be sent to chromecast device.
