Thank you for contributing this binding, glad to see this will be included in the 3.1 release!
I have managed to install the binding on OH 3.01, created a thing, and then two items (as switches) (setting both up through text files, not the UI) to read two input pins. But trying to read them through OH, things do not go as expected. I am not sure whether this is an issue with the binding, my circuit, or just me not understanding well enough gpio.
For context: I have a setup that worked well under OH2 with the old GPIO binding. Basically two sets of window contacts, one for each floor, which I feed from the 3.3V pin of the Pi and then read each through a simple circuit with a pull down resistor connected to pins 17 and 18. That circuit definitively continues to work, as eg pigs r 18 will show me the correct state of the window contact, and changes when I open or close a window.
Now, after configuring the thing and items, that seems to work in principle, as the item does sometimes get a state assigned. However, more often than not it does not (the state is NULL), and it does definitively not update states when windows are opened or closed. Also, the pigs r 18 command now ceases to work as expected, ie it will report 0 regardless of whether the window is open or not. In order to get back to the expected behavior of the pigs read command I had to reboot the Pi with the gpio contact; eg restarting the pigpiod service alone did not help.
I have tried this both on the raspi 4 on which OH is installed, as well as on a seperate raspi 3; same behavior in both cases.
I am increasingly thinking this might have much to do with my circuit. There is a lot of wiring in there, basically about ten windows on each floor; so the voltage coming back to the Pi might not be that much. But given this worked well with the OH2 binding, I was thinking perhaps the new binding is perhaps too aggressive in rapidly polling the gpio pins? Is there perhaps a way to significantly slow that down?
I know this is difficult to diagnose remotely, but any thoughts or input would be much appreciated.
