Hi, I got all my GPIO working to turn relays on and off, the only problem though is that the GPIO only stays on for 15 s then goes low again, and the state also changes in the GUI. How can I avoid this in a switch item?
It seems that there is soemthing wrong with permision of the sys/class/gpio. Do I need to do chmod -R755 on this folder?
I made this little shell script to test all my relays, however it doesnt work:
echo Initializing
echo 2 > unexport
echo 3 > unexport
echo 4 > unexport
echo 17 > unexport
echo 27 > unexport
echo 22 > unexport
echo 10 > unexport
echo 9 > unexport
echo 11 > unexport
echo 5 > unexport
echo 6 > unexport
echo 13 > unexport
echo 19 > unexport
echo 26 > unexport
echo 14 > unexport
echo 15 > unexport
echo 18 > unexport
echo 23 > unexport
echo 24 > unexport
echo 25 > unexport
echo 8 > unexport
echo 7 > unexport
echo 12 > unexport
echo 16 > unexport
echo 20 > unexport
echo 21 > unexport
echo 2 > export
echo 3 > export
echo 4 > export
echo 17 > export
echo 27 > export
echo 22 > export
echo 10 > export
echo 9 > export
echo 11 > export
echo 5 > export
echo 6 > export
echo 13 > export
echo 19 > export
echo 26 > export
echo 14 > export
echo 15 > export
echo 18 > export
echo 23 > export
echo 24 > export
echo 25 > export
echo 8 > export
echo 7 > export
echo 12 > export
echo 16 > export
echo 20 > export
echo 21 > export
echo out > gpio2/direction
echo out > gpio3/direction
echo out > gpio4/direction
echo out > gpio17/direction
echo out > gpio27/direction
echo out > gpio22/direction
echo out > gpio10/direction
echo out > gpio9/direction
echo out > gpio11/direction
echo out > gpio5/direction
echo out > gpio6/direction
echo out > gpio13/direction
echo out > gpio19/direction
echo out > gpio26/direction
echo out > gpio14/direction
echo out > gpio15/direction
echo out > gpio18/direction
echo out > gpio23/direction
echo out > gpio24/direction
echo out > gpio25/direction
echo out > gpio8/direction
echo out > gpio7/direction
echo out > gpio12/direction
echo out > gpio16/direction
echo out > gpio20/direction
echo out > gpio21/direction
echo Setting all gpio high
echo 1> gpio2/value
echo 1> gpio3/value
echo 1> gpio4/value
echo 1> gpio17/value
echo 1> gpio27/value
echo 1> gpio22/value
echo 1> gpio10/value
echo 1> gpio9/value
echo 1> gpio11/value
echo 1> gpio5/value
echo 1> gpio6/value
echo 1> gpio13/value
echo 1> gpio19/value
echo 1> gpio26/value
echo 1> gpio14/value
echo 1> gpio15/value
echo 1> gpio18/value
echo 1> gpio23/value
echo 1> gpio24/value
echo 1> gpio25/value
echo 1> gpio8/value
echo 1> gpio7/value
echo 1> gpio12/value
echo 1> gpio16/value
echo 1> gpio20/value
echo 1> gpio21/value
sleep 20
echo Unexporting all
echo 2 > unexport
echo 3 > unexport
echo 4 > unexport
echo 17 > unexport
echo 27 > unexport
echo 22 > unexport
echo 10 > unexport
echo 9 > unexport
echo 11 > unexport
echo 5 > unexport
echo 6 > unexport
echo 13 > unexport
echo 19 > unexport
echo 26 > unexport
echo 14 > unexport
echo 15 > unexport
echo 18 > unexport
echo 23 > unexport
echo 24 > unexport
echo 25 > unexport
echo 8 > unexport
echo 7 > unexport
echo 12 > unexport
echo 16 > unexport
echo 20 > unexport
echo 21 > unexport
cd /home/pi/openhab
I also cleared my rules file and stripped my item file:
Group All
Group GF_Kitchen
Group GF_Living
Group FF_Bath
Group FF_Bed
Group FF_MasterBedroom
Group GF_Toilet
Group GF_Corridor
/* active groups */
Group:Switch:OR(ON, OFF) Lights "All Lights [(%d)]" (All)
Group:Switch:OR(ON, OFF) Heating "No. of Active Heatings [(%d)]" <heating> (All)
/* Lights */
Switch Light_GF_Living_Table "Module 1" (GF_Living, Lights) { gpio="pin:12" }
Switch Light_GF_Center "Module 2" (GF_Living, Lights) { gpio="pin:19" }
Switch Light_GF_Tv "Module 3" (GF_Living, Lights) { gpio="pin:16" }
Switch Light_GF_Bar "Module 4" (GF_Living, Lights) { gpio="pin:26" }
Switch Light_GF_Elefant "Elefant" (GF_Living, Lights) { gpio="pin:6" }
Switch Light_GF_Glass "Glass" (GF_Living, Lights) { gpio="pin:13" }
Switch Light_GF_WallWasher "Wall washer" (GF_Living, Lights) { gpio="pin:20" }
Switch Light_FF_Bath_Ceiling "Ceiling" (FF_Bath, Lights) { gpio="pin:9" }
Switch Light_SF_Corridor_Ceiling "Ceiling" (GF_Corridor, Lights) { gpio="pin:10" }
Switch Light_SF_Corridor_Door "Door Opener" <heating> (GF_Corridor, Lights) { gpio="pin:22" }
/* Heating */
Switch Heating_GF_Corridor "Hallway Heating" <heating> (GF_Corridor, Heating) { gpio="pin:17" }
Switch Heating_GF_Living "Livingroom" <heating> (GF_Living, Heating){ gpio="pin:27" }
Switch Heating_GF_Kitchen "Kitchen" <heating> (GF_Kitchen, Heating){ gpio="pin:11" }
Switch Heating_FF_Bath "Bath" <heating> (FF_Bath, Heating){ gpio="pin:5" }
Switch Heating_FF_Office "Master bedroom" <heating> (FF_MasterBedroom , Heating){ gpio="pin:21" }
Switch Heating_FF_Bed "Bedroom" <heating> (FF_Bed, Heating){ gpio="pin:4" }
This is the rc.local file I use
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
printf "My IP address is %s\n" "$_IP"
fi
chgrp -R dialout /sys/class/gpio
chmod -R g+rw /sys/class/gpio
sudo /home/pi/openhab/start.sh &
exit 0
Any ideas where the problem can be?
