After a reboot yesterday my openhab installation cant use mye GPIOpins (RPi2).
I have a relay connected to four pins on rpi, the relay is working because it switches the lights when rpi is rebooting.
But nothing happens when i use the switch in openhab, i can see some strange info in the logfile when openhab starts.
I have copied the lines of the log i think is making problems.
As far as i can see the GPIO binding is loaded, but what about the loading of 2 config files (from /etc/openhab and /usr/share/)?
10:49:11.325 [INFO ] [rg.quartz.core.QuartzScheduler:268 ] - Scheduler meta-data: Quartz Scheduler (v2.1.7) 'openHAB-job-scheduler' with instanceId 'NON_CLUSTERED'
Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 2 threads.
Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered.
10:49:11.384 [DEBUG] [o.config.core.ConfigDispatcher:146 ] - Processing openHAB default configuration file '/usr/share/openhab/configurations/openhab_default.cfg'.
10:49:12.594 [DEBUG] [o.config.core.ConfigDispatcher:168 ] - Processing openHAB main configuration file '/etc/openhab/configurations/openhab.cfg'.
10:49:13.652 [DEBUG] [.o.core.internal.CoreActivator:93 ] - UUID file already exists at '/usr/share/openhab/webapps/static/uuid' with content '7ee9ba60-baae-45ec-85e7-81bd79297570'
10:49:13.663 [DEBUG] [.o.core.internal.CoreActivator:115 ] - Created file '/usr/share/openhab/webapps/static/version' with content '1.8.0'
10:49:57.983 [INFO ] [org.atmosphere.util.IOUtils :370 ] - META-INF/services/org.atmosphere.cpr.AtmosphereFramework not found in class loader
10:49:58.725 [INFO ] [sphere.cpr.AtmosphereFramework:2601 ] - Atmosphere is using org.atmosphere.cpr.DefaultAnnotationProcessor for processing annotation
10:49:59.038 [INFO ] [cpr.DefaultAnnotationProcessor:138 ] - AnnotationProcessor class org.atmosphere.cpr.DefaultAnnotationProcessor$BytecodeBasedAnnotationProcessor being used
10:49:59.580 [WARN ] [cpr.DefaultAnnotationProcessor:178 ] - Unable to detect annotations. Application may fail to deploy.
10:50:58.133 [DEBUG] [o.o.b.g.i.GPIOBindingActivator:30 ] - GPIO binding has been started.
10:50:58.662 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Lys_Stue_Tak (Type=SwitchItem, State=Uninitialized)' with 'GPIOGenericBindingProvider' reader.
10:50:58.676 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Lys_Stue_Firkant1 (Type=SwitchItem, State=Uninitialized)' with 'GPIOGenericBindingProvider' reader.
10:50:58.684 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item 'Lys_Stue_Fargelamper (Type=SwitchItem, State=Uninitialized)' with 'GPIOGenericBindingProvider' reader.
10:50:58.692 [DEBUG] [i.internal.GenericItemProvider:341 ] - Start processing binding configuration of Item
Other parts of the openhab works (weather, ssh/exec)
Events.log (The last three is the GPIO bindings that does not work):
2016-01-21 14:19:22 - Weather_Temp_Min_2 state updated to -3.1
2016-01-21 14:19:22 - Weather_Wind_Gust state updated to Undefined
2016-01-21 14:19:22 - Weather_Temperature_Feels state updated to -17.58
2016-01-21 14:22:02 - Lys_Stue_Fargelamper received command ON
2016-01-21 14:22:04 - Lys_Stue_Firkant1 received command ON
2016-01-21 14:22:04 - Lys_Stue_Firkant2 received command ON
