No, tried but it was not successful
Quang-Tuyen Tran
quangtuyen.tran@gmx.de
(+49) 015237376688
I can now use GPIO as Input on OpenHAB 2 using Snapshot 2.1.0 Build #887
For GPIO Bindig i am using GPIO Binding Snapshot 1.10.0.201704230111
1 . The first you need install libjna 3.2.7 on your raspberry:
sudo apt-get autoremove libjna-java
sudo wget http://ftp.debian.org/debian/pool/main/libj/libjna-java/libjna-java_3.2.7-4_armhf.deb
sudo dpkg -i libjna-java_3.2.7-d_armhf.deb
2 . You need take a new file gpio.cfg into the folder: /etc/openhab2/services with this code:
sysfs=/sys
debounce=10
3 . add gpio to openhab group:
sudo adduser openhab gpio
4 . Example for items file:
Contact ws_hall {gpio="pin:17 debounce:10 activelow:yes"}
5 . Example for rules file:
rule "hall light"
Item ws_hall received update CLOSED
if (hall_light.state==OFF) {
hall_light.sendCommand(ON)
} else {
hall_light.sendCommand(OFF)
i hope this info can help someone
