Answered my own question… had the wrong type of quotes (curly instead of straight) in the HTTP Body parameter string.
Hello everyone,
Excellent binding so thank you.
May I ask after searching all the forums, I am still confused with the below.
I have added a “distance” channel via paperui. I basically want to display in a widget the distance from a home location for each GPSTracker thing I have added. However it doesnt seem to work as expected.
Can someone explain how to setup this function so it does exactly what I describe? I have no errors currently, just really inaccurate readings of that distance channel. For example my location might be 80 miles away from the home longitude/latitude set but the value will display nearly half that amount or sometimes not at all e.g NULL
Any newbie explanation would be most appreciated.
Matt
I’ve made some changes to the binding (OH3 version only) improving the region channel triggering. It’s a WIP at the moment, but I could use some help with testing before finalizing the PR that fixes
The addon jar can be downloaded from here
https://openhab.jfrog.io/artifactory/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.gpstracker/3.1.0-SNAPSHOT/org.openhab.binding.gpstracker-3.1.0-SNAPSHOT.jar
Could this binding be easily modified to work with OwnTracks clients connected via MQTT as well as HTTP? MQTT according to the makers likely uses less battery albeit with an extra server port open, and I currently use it with a rule to get geofence and distance away functionality
https://owntracks.org/booklet/features/android/
“It is highly recommended to use HTTP mode on Android 6 and higher.”
I’m using IOS, but I’ll keep that in mind, maybe HTTP is their future direction.
I have always issues on IOS. It always stops reporting after one or two days. Wich one is better? Owntracks or Life360? Owntrack can use Ibacon on IOS, but it needs to be configured in the reagon settings. Is that possible to add this parameter? When region is configured through Openhab this parameter is not avaiable.
IBeacon is a device that can be used to force triggering an OT location update from your phone to the binding when you enter/leave a region. Its configuration has nothing to do with the binding itself as your phone is not aware of regions configured in the binding.
Hi!
When trying to install binding, I get the following error:
2021-04-12 16:44:16.319 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
2021-04-12 16:44:16.517 [WARN ] [onfig.core.ConfigDescriptionRegistry] - bundle org.openhab.core.config.core:3.1.0.202104110753 (150)[org.openhab.core.config.core.ConfigDescriptionRegistry(100)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.521 [WARN ] [onfig.core.ConfigDescriptionRegistry] - bundle org.openhab.core.config.core:3.1.0.202104110753 (150)[org.openhab.core.config.core.ConfigDescriptionRegistry(100)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ConfigOptionProvider
2021-04-12 16:44:16.527 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
2021-04-12 16:44:16.541 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.202104110755 (151)[org.openhab.core.config.discovery.internal.PersistentInbox(111)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.544 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.202104110755 (151)[org.openhab.core.config.discovery.internal.PersistentInbox(111)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ThingHandlerFactory
2021-04-12 16:44:16.549 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
2021-04-12 16:44:16.605 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:3.1.0.202104110754 (199)[org.openhab.core.thing.internal.ThingRegistryImpl(234)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.609 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:3.1.0.202104110754 (199)[org.openhab.core.thing.internal.ThingRegistryImpl(234)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ThingHandlerFactory
Am I doing something wrong?
openHAB 3.1.0
Build #2322
Binding was downloaded from the link above and placed in the addons folder, oh3 rebooted three times, error on each reboot.
I’m on 3.1.0.M3 which has all the changes merged. Not seeing this…
Is there any description how to set up life360? Iphone always changes location sharing settings from always to in use and I can’t stop it.
openHAB 3.1.0
Build #2322
I don’t see binding at all.
@gbicskei what happend to the Life360 support? Iam running OH 3.1.0 and can’t see any life360 settings in GPS tracker.,
Or is the Life360-to-gpstracker script the way to go? https://community.openhab.org/t/linking-life360-and-oh2-gpstracker-a-simple-script/76050/8
+1
I’m also interested in life360.
I tried it through node-ed, but the functionality is limited.
is there a binding for life360?Gpstracker binding works with Owntracks only?
Hello, Can the phone charging information be added as a channel in the GPSLogger application? Defined as “%ISCHARGING” in the application.
If I understand all this right, this hack is for using Life360 as a source of gps-data while also using the owntracks add-on?
And I think this was done in OH2 right?
Can anybody tell me if this would still work in OH3?
I have been away from home automation since about a year. Now I upgraded from Habian2.4 to OH3.4.2 in Docker. I didn’t have geo fencing before, but now all of my family have Life360 running and I would love to make a ‘Weasley location clock’.
