@gbicskei are you still around? It would be good if your binding updates could be considered for one of the 2.5.x patch releases. Do you have plans to do so?
May I ask after searching all the forums, I am still confused with the below.
I have added a “distance” channel via paperui. I basically want to display in a widget the distance from a home location for each GPSTracker thing I have added. However it doesnt seem to work as expected.
Can someone explain how to setup this function so it does exactly what I describe? I have no errors currently, just really inaccurate readings of that distance channel. For example my location might be 80 miles away from the home longitude/latitude set but the value will display nearly half that amount or sometimes not at all e.g NULL
I’ve made some changes to the binding (OH3 version only) improving the region channel triggering. It’s a WIP at the moment, but I could use some help with testing before finalizing the PR that fixes
Could this binding be easily modified to work with OwnTracks clients connected via MQTT as well as HTTP? MQTT according to the makers likely uses less battery albeit with an extra server port open, and I currently use it with a rule to get geofence and distance away functionality
I have always issues on IOS. It always stops reporting after one or two days. Wich one is better? Owntracks or Life360? Owntrack can use Ibacon on IOS, but it needs to be configured in the reagon settings. Is that possible to add this parameter? When region is configured through Openhab this parameter is not avaiable.
IBeacon is a device that can be used to force triggering an OT location update from your phone to the binding when you enter/leave a region. Its configuration has nothing to do with the binding itself as your phone is not aware of regions configured in the binding.
Hi!
When trying to install binding, I get the following error:
2021-04-12 16:44:16.319 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:490) ~[?:?]
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:316) ~[bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1000) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:973) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:918) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:216) [org.eclipse.osgi-3.16.200.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:213) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:114) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:533) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:656) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:675) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2556) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2075) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2058) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:443) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:333) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:301) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1200) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1121) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:928) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:864) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1152) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:114) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:120) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:957) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:936) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:873) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:261) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:496) [org.eclipse.osgi-3.16.200.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:929) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:915) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:984) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:752) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:437) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:667) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:305) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:554) [bundleFile:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:70) [bundleFile:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:421) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [bundleFile:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [bundleFile:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [osgi.core-7.0.0.jar:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-7.0.0.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:945) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:232) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.Module.start(Module.java:486) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.16.200.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.16.200.jar:?]
2021-04-12 16:44:16.517 [WARN ] [onfig.core.ConfigDescriptionRegistry] - bundle org.openhab.core.config.core:3.1.0.202104110753 (150)[org.openhab.core.config.core.ConfigDescriptionRegistry(100)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.521 [WARN ] [onfig.core.ConfigDescriptionRegistry] - bundle org.openhab.core.config.core:3.1.0.202104110753 (150)[org.openhab.core.config.core.ConfigDescriptionRegistry(100)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ConfigOptionProvider
2021-04-12 16:44:16.527 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
2021-04-12 16:44:16.541 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.202104110755 (151)[org.openhab.core.config.discovery.internal.PersistentInbox(111)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.544 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:3.1.0.202104110755 (151)[org.openhab.core.config.discovery.internal.PersistentInbox(111)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ThingHandlerFactory
2021-04-12 16:44:16.549 [ERROR] [er.internal.GPSTrackerHandlerFactory] - bundle org.openhab.binding.gpstracker:3.1.0.202104120740 (262)[org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory(313)] : Error during instantiation of the implementation object
2021-04-12 16:44:16.605 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:3.1.0.202104110754 (199)[org.openhab.core.thing.internal.ThingRegistryImpl(234)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313}
2021-04-12 16:44:16.609 [WARN ] [ore.thing.internal.ThingRegistryImpl] - bundle org.openhab.core.thing:3.1.0.202104110754 (199)[org.openhab.core.thing.internal.ThingRegistryImpl(234)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.core.config.core.ConfigOptionProvider}={service.id=585, service.bundleid=262, service.scope=bundle, component.name=org.openhab.binding.gpstracker.internal.GPSTrackerHandlerFactory, component.id=313} for reference ThingHandlerFactory
Am I doing something wrong?
openHAB 3.1.0
Build #2322
Binding was downloaded from the link above and placed in the addons folder, oh3 rebooted three times, error on each reboot.
